Thanks for replying, and for your questions.
The views are the main reason we have the glass at the back, I will try to post some pictures up when I get a chance
The views are the main reason we have the glass at the back, I will try to post some pictures up when I get a chance.
As we are hopefully planning on using ICF construction, and if possible frameless glass, from my understanding we may use a cantilever design with obviously the additional steelwork/cage above the corner window
I don't think we are too concerned with the large area of glazing on the rear elevation as I believe we will either be utilizing a large steel goal post type structure or additional steel within the ICF structure (columns) if applicable on the corners.
This will hopefully be things that the engineer can clarify, fingers crossed.
We just need a bit of luck to get through planning now!!
