andadam
andadam's Achievements
New Member
New Member (2/5)
0
  1. Hello, I am ready to order steel for my building project. Its an open plan extension. I have had the steels specified by an engineer but just want be clear of what to order. The opening is in a 1930s semi detached house (solid 9 inch wall) and is approx 7.5 metres with 2 point loads. The engineer has given me 2 options for the main beam: 1) use 254 x 254 x 167kg (This option is not practical as due to the overall weight and would need crane to lift off flat bed and into position) 2) use 2no x 203 x 203 x 113kg - I am going to go for this option. The steel will sit on goalpost support columns at each end 203 x 203 x 46 UC on 250 x250 x 8mm Base plate With 250 x 250 x 20mm head and sole plates My question is - Do I need 2 goalposts at each end or just 1 with a bigger head plate to match the total width of the 2 steels bolted together (16 inch)? Thanks
