Philipc
Personal Information
  • Location
    liphook
Philipc's Achievements
New Member
New Member (2/5)
0
  1. Thanks for this response "If it meets the definition of a conservatory, it would be exempt from Building Regulations" By this you mean if it met the definition of a conservatory, it would not require planning permission? forgive my ignorance of the terminology.
  2. Hello folks I want to build a single storey room at the side/rear of my house. A simple, wooden framed, dwarf brick wall conservatory. No knocking through walls etc. It would be within one metre of the boundary (my neighbour is fine with this). The room would project one metre out from the side of the house. The house faces onto a road. The room would be 4.5 metres long. See attached sketch. I assume planning permission will be required, but I’d like to 'second guess' the likely outcome of any such application, before I waste too much time/cash. Or indeed whether there are things I could consider, which might make any application more likely to succeed? What does Build Hub think? Thanks in anticipation.
