Bounce
Bounce's Achievements
Member (3/5)
2
Sorry i was meant to say part grey brick and rest render where there is no grey brick. I've attached another photo that's all of the exposed element currently, I will try take a better one tomorrow. Now looking at it the small bricks look like they could have been used to bond the two walls together?
I need some advice on replacing the bricks on the lower half of an external wall on our 1920s home. The top half of the wall is currently rendered, and we eventually plan to re-render the entire house to match a new, lighter aesthetic. Our current focus is on removing the existing red bricks from the bottom half of an external wall and replacing them with light grey bricks. We've noticed a gap of approximately 10mm between the outer brickwork and the inner wall. There's no existing insulation in this gap, so we're planning to add insulating plasterboard to the interior. A significant concern is the apparent absence of wall ties connecting the outer and inner walls. Given these observations, what's the best approach to replacing the bricks? We're particularly interested in understanding if this is a straightforward "swap" of facing bricks, or if more extensive work is required due to the lack of wall ties. The chimney breast on the inner wall is coming out, so the inner wall on the bottom half may also be rebuilt with blocks. Also if there is no wall ties in the bottom half, we don't know about the top half. We are going to have the chimney breast removed from the top half, but may not need to rebuild that part of the wall, not sure at this stage. Our goal is to ensure the job is done correctly when we instruct a professional. Any guidance you can offer would be greatly appreciated.
Are some snots and caps a problem on the inside of a new brick wall?
Bounce replied to Bounce's topic in Brick & Block
Thanks appreciate that info.. In regards to saving money, they are supplying all the materials etc, so any additional costs for this, will be paid for by them, I just want to make sure it's all done correctly. -
I assume they didn't want to damage the outer bricks, as they came from Germany. Plus they are expensive and take 3-4 weeks to get more. -
Thanks all.. I'd spoken to recticel this morning over the phone and email. They've also confirmed in writing that it doesn't look correct. I went armed with this information and the instructions of how to Install this insulation. The building firm we've used, subcontracted the bricklaying out, and our building firm, didn't QC/Oversee it, it took me to notice it. They have agreed to rectify it from tomorrow. I think they are potentially going to take the blocks (inner skin) down and relay them, with the insulation attached properly. Do you think this possible? I've got to meet them again on site tomorrow to go over it what they will be doing. -
Thanks. Is that something that can be done without removing the inner or outer skin? -
Thanks. They are about 2/3 of the way up for the ground floor, still a bit more to go to finish ground floor, then they'll start on the upstairs. This one seems flush against internal wall, but the gap between external wall has snots. Again they've not used cavity clips to hold it tight against the wall, although there isn't any movement, I assume because of the snots. -
Can we get a building inspector to check this? I am thinking, if they say its fine, I could suggest getting it checked if they are confident it's ok. If they say it's ok, we carry on, if not they rectify...? -
Or they take the outer skin down and start again? Doubt they'll want to do that though..
