Morning,I have moved into a new-to-me 1950s bungalow about 8 weeks ago. It has a garage, which is best considered detatched.The garage has an asbestos roof, brick walls and minimal joists to support the roof, and is 6m x 3.5m.
I will need to replace and improve the joist/supporting roof structure.Over the last few weeks I have noticed that the roof is actually leaking (I had replaced the guttering as I thought that was the problem).This means I would like to add a new roof as cheaply as possible, so I have been looking at corrugated bitumen. Any experience or thoughts?I am not a builder, and have not built a roof before. I am practical and a Mechanical Engineer by profession, and happy to learn...Please see photos of existing garage https://photos.app.goo.gl/Xd94qa4haf57amrV9The roof of the house over hangs part of the roof of the garage (it is "semi-attached" on a single corner). So building a roof with joists resting on wall plates isn't an option. So I have been looking at using joist hangers, and therefore positioning the joists between the walls.I have a few questions...
It is a flat roof with less than 10 degrees slope, is it ok to have the joist not horizontal? Or should I make them horizontal and then create angle in another way? I'm concerned at the use of joist hangers not perpendicular.
Should I attach OSB to the top of the joists to make it easier to add the corrugated sheets? Or would battens be easier?
Should I seal where the corrugated sheets meet the top of the wall plate? This would stop animals and insects getting in, but would remove any ventilation. I presume condensation will be an issue if I did this?
Would I be better to OSB the bottom of the joists to seal the garage space, and then ventilate above by not sealing the corrugated sheets to the top of the wall? Would I need a vapour barrier? How would I protect against insects and birds?
Most important question; am I thinking about this too much? I don't want a wet, cold, draughty garage to work in...Any help appreciated,Rich
