Hash
Everything posted by Hash
  1. Hash
    ?Rising Damp?
    If not concret floor that the old way of air bricks and floating wood beams with an air cavity under to allow for air to pass through?
  2. Hash
    ?Rising Damp?
    The floor outside is maybe a few cm lower than the concrete inside at present
  3. Hash
    ?Rising Damp?
    Hi all Gf purchased semi detached house which is ?100+yrs old (not too sure on this myself but as per survey). We were stripping one of the ground floor walls of plaster as she wanted an bare brick feature wall. As we were doing noted that the lower 2 layers of brick were wet so tore up floor and the ends of wooden timbers under the chipboard was rotting black and mushy. The beams were sitting on an uneven concrete floor. All edges of the concrete floor where it met the brickwork im the whole room was surrounded by a visibly damp line. The room had previously had a flood from a lealy pipe which had been repaired prior to being bought. There didnt seem to be a DPM under the concrete and it appeared to be sitting on soil underneath so after a lot of back and forth we deiced to take up a little and see if we could establish if there was a in the brickword below the soil (slate) that the concrete was sittinf above, a dpm under the concrete thatbwasnt sitting in visible brickwork or if could find a leak as there were some pipes feeding under concrete. Dug up a little more than though would keed to but cant find any evidence of slate layer, no dpm at all, wet clay/soil under conxrete and some old broke pipe but not leaking. Also found a hole in brickwork which may have been a ?airbrick at some point? Im no querying taking up concrete digging down about 40ish cm deep and placing some air bricks feeding into a ventilating pipe going round the walls and then placing gravel and relaying concrete with a polythene dpm. Way a little over my head here so any help is appreciated. Someone has mentioned that the room seems to have been a converted garage which is contributing to damp? Dehumidfers are on round the clock for around 2 months but no luck, any ideas? Ive uploaded the images to help visualise https://ibb.co/album/tLDJwR
