Ian Nixon
Everything posted by Ian Nixon
What I am trying is turning off the upstairs heating which is the rads, this might be where the problem lies? Just trying something.
Yes I reckon that’s what does happen. Oh ok I will suggest this to my engineer. Can you set that kind of stuff some where? thanks for all your help Ian
There is nothing else except the immersion heater. That’s all. im getting a stat fitted so that will sort that problem out. But I’m still passed about the EE-03 error. I think change the sensor is next thing but then I’m sure it will do it all the time if it was this and not just when HW is on timer ?????
Sorry don’t know what you mean by just heating hot water by timer? What ways are there???????
So my engineer is correct then. I only have this one fitted. Hence why when I have hot water timer on, the pump never stops and costs me lots but if I put the hot water on the time I go back to the bloody beginning of why I posted with the sodding EE-03 error. I’ve tried speeding up the pump. Not having the heating and hot water running together? And some other adjustments. It’s a bloody nightmare.
Aparently it’s not good though having this one fitted. Will be costing me more and not efficient? It’s not got a stat fitted either so everything wrong with it really. Also supposed to have a filter fitted on the return to ashp but it hadn’t so think a bit of a refit is needed. Will the right tank make all the difference do you think??
Further update if people can help please? I have the wrong hot water tank installed. Aparently it should be one for an ashp as they are different, can anyone offer advice please. See picture of mine.
Temperature of hot water leaving your ashp
Ian Nixon replied to Ian Nixon's topic in Air Source Heat Pumps (ASHP)
That’s what I do. -
I see what you are saying. I do think it is a cheap Chinese one been fitted though lol -
I’ve got a manual. I have a plate with a part number on but I’m unsure what you are getting at? I know it only has one setting to put a temperature in as it was the manufacturer who called me and told me what to do. -
Its make is Dream -
Oh I see that’s good. Mine only has 1 temp and then a thermostat on the ufh manifold to turn the temp down. Mine runs both st same time but I don’t think it should -
Hi what temperature do most people run there ashp on for the water leaving it? i believe this is the temp for the dhw and the water in the heating system
News, I spoke to the manufacturer of my ashp about the temp and they said to check on my programme 1 and guess what? It was set to 40 degrees that’s why it wasn’t hot. They told me to set it at 55 degrees but I set it to 50 degrees and now the water is hot. So one problem down. Just got to sort the error so I can stop having my pump running 24/7 and we should be there ?
I’m not talking when the weather has been that low. Say 5 degrees at night and then need to shower in morning. How hot is your water temp. also can you adjust the water temp leaving ashp. Why can you amend the water inlet temp? I don’t understand this?
Do anybody have hot water problems with ashp, I.e sometimes not that hot. I’ve added my immersion to come on a little to help. can you turn up the hot water the ashp provides? Or what do others experience or do please. thanks
Ok how do I know or try to remove
It was on high when I checked. But something strange going on, I switched water off like I said I had done and then it puts the error up. When I went through settings on pump still error but then when I got to number 3 setting which is just high like on a normal pump the error went and it started. I switched off the air source heat pump a couple of times and now guess what I put the pump back on the setting I had it on and now no error when I have water on timer? What the hell is all this about. It sounds more like electrical to me????
No I haven’t tried the faster pump speed. I will do that tomorrow and let you know. Thank you
Hi any further help or advice please? thanks
Hi all, ok I haven’t turned up the ashp Pump speed yet but will do but if I keep on the timer switch for hw as always on I don’t get the error but what I did notice is though the ashp isn’t operating so no need for heat or hw, the pump on the outside so next to ashp it’s always running????? Sure if don’t need hot water should this be running 24/7.
