Hi,
	Recently, I bought house and found it has penetration damp on gable end. As far as my investigation goes. Source of the damp is faulty points.
	I have removed all plaster from the wall. Practically. I am down to original brick. I am planning to put insulated plaster board with moisture barrier. Do you think I should be mindful before applying insulated plasterboard.  If yes, what kind of treatment should I do.
	last question,
	It's a solid brick wall and had paint before I bought the house. Now I found that solid wall suppose to breath. If the breathability issue comes then it will start the problem. So, I don't want to leave the wall as it is after repoint. So, what kind of paint I should use?
	Thanks for reading my query.
	Cheers!
