Krishna24
Krishna24's Achievements
New Member
New Member (2/5)
0
  1. Mike, external wall insulation is out of question for now (too expensive). What kind of vapor permeable masonry paint I should use. Any recommendations of website or brand. Thanks
  2. There is chimney. However, no issues around chimney at all.
  3. Here are some pictures of the internal and external wall. When I bought the house, each wall had wallpapers and these wall paper were quite thick. After investigation I realise points has gone through first floor. So, whenever it's raining and have wind water is penetrating through. Now, I m bit confused regarding putting a layer of masonry paint. Gable end had paint and can see the some places face of the brick has blow. From research I found that it only happens when. Wall is anablw to breath and moisture is trapped. Do you think I should apply any masonry paint on gable end to stop water going through? If yes what would be the best option. Ofcouse I would prefer wall to breath. Last question, what treatment I should do before plasterboarding the wall? Thanks
  4. Hi, Recently, I bought house and found it has penetration damp on gable end. As far as my investigation goes. Source of the damp is faulty points. I have removed all plaster from the wall. Practically. I am down to original brick. I am planning to put insulated plaster board with moisture barrier. Do you think I should be mindful before applying insulated plasterboard. If yes, what kind of treatment should I do. last question, It's a solid brick wall and had paint before I bought the house. Now I found that solid wall suppose to breath. If the breathability issue comes then it will start the problem. So, I don't want to leave the wall as it is after repoint. So, what kind of paint I should use? Thanks for reading my query. Cheers!
