recognized
recognized's Achievements
New Member
New Member (2/5)
0
  1. That what I actually meant with "its vogue about it" in a nutshell I just want to something of similar size like on the picture minus pergola thing beside it and roof of that corrugated plastic that you usually seen used in these applications. Mine is picture 3 (satellite). As I understand pergola becomes a veranda as soon as you attach it to the house? What about the decking under 300mm?
  2. Hello Everyone, I have just been reading this and it seems a bit excessive for what I want to achieve. I abandoned the Idea with a veranda and now wonder what if I build some pergola with a decking underneath? It is less than 30 sq meters and will not be attached to the house. The road is only to the front of the house and there is a driveway to one side of the thing I want to build and a neighbour to the other. If I make it around below 3m maximum height it should be fine? What if I attach it to the house? My main goal is to have a bit of a dry area in the garden during wet times.
  3. Hello, This is my first time writing here. I want to build a Lean to veranda to the back of the house. It is a semi-detached property build in 2020. There is no conservation etc. How high I can start for that Lean-to ? Building regs are quite vogue about it.
