OJC
OJC's Achievements
New Member
New Member (2/5)
0
  1. Thanks for your replys!! To do the whole thing (3 of all 4 walls have some blocks on them, existing is brick) is just outside our budget at the minute. Ill definitely look at the DIY option as that sounds relatively cheap. Mr Punter, yeah he’s saying it has to be done for sign off. Thanks again
  2. Hi Nod, thanks for your reply. Is there anything I can do as a temp fix before render? Im worried that the BI is going to issue a Contravention Notice as they’ve already extended the timeframe a couple of times.
  3. Hello, I’ve had an extension done using concrete blocks as the plan is to render. However, the budget has worn thin so I can’t afford the render right now and Building Regs are pestering me to get the project completed. Im therefore looking for a product that would seal the block work whilst being Building Regs compliant. I did find a product by Safeguard, that is BBA certified but the building inspector claims this certificate isn’t good enough for sign off using that product. Any help greatly appreciated!
