Thanks again.
I am replacing all windows and doors now plus the external wall insulation and floor insulation. Can you advice where i can get the design done i.e what kind of ducting to run, manifolds, silencers etc. where to locate the vents?
Thanks for your reply.
Considering the house is currently totally stripped, I need to run the ducting soon. Would it be different ducting for MEV and MVHR?
Hi
I am in a process of full renovation of a 1930s semi. all walls stripped to brick, external wall insulation, 150mm insulation between joists and 6 m rear extension. I am thinking of installing a MVHR. The question is, is it worth it for an old house?
If yes, where can I get the design done? Don't mind if it is a paid design.
Thanks
