Potatoman
Everything posted by Potatoman
  1. Thanks for all your suggestions, I quite like the thought of dMEV fans but as it is retrofit project how would I power them?
  2. Hi, been talking to Vent Axia about their centralised MEV system and they have said I need to get somebody to survey the bungalow as you need to measure duct length and pressure build up, etc to get the correct system for the job, is this correct. Or is there a better way to tailor the system to the house.
  3. Hi I have a 85sq m Bungalow which is pretty well sealed up, so consequently got mould problems. Thinking about getting some window vents fitted and a PIV system, what does anybody think of these, whats a good make to get, should I get one with a heater in or not, are they expensive to run with a heater in. anything I have missed ?Thanks in advance
  4. Unfortunately, it's all radiators
  5. Hi, I would like to fit a 28 mm fill and flush valve to my system, but the valve reduces the bore to about 20mm for about 35mm in length, will this have any effect on the flow/ efficiency of my system. Thanks
  6. Thanks for that, I have a buffer and separate hot water tank, my worries are after flushing the system and refilling I end up with air in the system like the buffer tank,hot water tank or the circulating pump. Would all this trapped air eventually make its way to the automatic bleeding valves.
  7. That's interesting, where did you position it and how did you get to drain/fill the hot water tank.
  8. If I did that idea, how do I get glycol back in the system
  9. Hi, how do you eliminate stubborn air in the heat pump system when you have a single zone system.
  10. Unfortunately not 😔
  11. How do you know what type of glycol you have in the system, and if you can't does it matter.
  12. Could you isolate and drain a radiator then fill with neat glycol
  13. So if you found the glycol in your system was too low, how would you top it up?
  14. Unfortunately, I need to keep an eye on the glycol levels in my system as it is a hybrid system with an oil boiler which comes on at about +5 degrees C, so I am going to need frost protection. At the moment I am using a refractometer and draining a radiator and topping up with glycol, if it needs topping up, Just wondered if there was a better way.
  15. Hi, what's the best way to add glycol to the heat pump system.
  16. Hi, thank you for your reply, to try and answer your questions, The problem I have got is the installer has left me with wiser controls and has told me that these controls will work when in ASHP mode or 3rd party boiler mode, but they don't, the wiser controls do switch the heat pump off and on but when in 3rd party mode do not switch off the oil boiler, so consequently the house gets too warm. Now I know wiser controls are not the best for ASHP but my problem at the moment is to get the 3rd party boiler working correctly and the reason to have a 3rd party boiler is heat pumps are less efficient at minus temperatures.
  17. Thank you for all the interesting replies, can we talk generically, if you wanted to set up a ASHP e.g. LG and a 3rd party boiler to work as they should do how would you set up the heating controls so it maintained a temperature of 21 degrees in the house if you had the choice of WC or Wiser controls, and how would everything work together, Thanks
  18. Hi, the ASHP is an LG 9KW monobloc, all radiator system, the system was left by the installer with Drayton wiser smart radiator valves controlling the heat pump, fixed flow rate, but now all rad valves are set at 23 degrees and weather compensation is operating. The 3rd party boiler is a Worcester 18 /25 oil boiler connected to the ASHP via a cable. As I understand it, when the outside temperature drops below 5 degrees C, which is set via the heat pump controls, the heat pump stops working and sends an electrical signal to the oil boiler to fire up, but when this happens what will control the temperature in the rooms if the heat pump is switched off
  19. Hi, could anybody tell me what controls the temperature of the rooms in the house when the 3rd party boiler is selected on the heat pump. Thanks.
  20. Hi, has anybody got a step-by-step installation guide to connect my Shelly energy meter to cloud/ phone. Thanks
  21. Can anybody tell me if this calculation holds water. Heat loss calculation of my house is 5.8Kw at -2 for 21 degrees inside. So to raise the temperature of my house I require 252w/degree 5800 divided by temp difference 23 So if you take average outside temp - average inside temp 0-21 =21 21 x 252 = 5292w 5.3kW x 24 = 127 kWhr/day divided by the actual kWHr used, in this case 41 kWHr would this give a COP of 3.097 ?
  22. Hi, is there a calculation you can make to determine the daily COP of a system. Thanks
  23. That's great, Thanks
  24. Hi, can anybody tell me what the flow rate from my 9kw LG ASHP should be given a 5.8 KW heat loss and using glycol, thanks
