Walshie
Everything posted by Walshie
  1. Hi, I’d appreciate some recommendations on the best clear, satin UV protection for Thermowood cladding? My main aim is UV protection and to avoid / slow any fade. Appreciate that I’ll need to re-treat every 2-3 years - but I’m ok with that. Grateful any recommendations! Thx
  2. Hi, Im building a timber veranda with a zinc standing seam roof. I plan to set two glazed panels into the roof above two sets of French doors. I’m considering what type of glazed panels to use. I’ve looked at standard double glazed units, but these seem to come up quite pricy. I’m need two panels - 1100 wide x 1500 long. Could I use just 6mm toughened glass and make a frame? Would this be sufficiently robust? Any thoughts on safe, cost effective alternatives? Thanks very much! W
  3. Hi, I’m starting to see the light at the end of the tunnel after a major rebuild. I plan to finish with a Victorian type veranda on the front of the house. It will be about 10m wide and about 2.4m deep. I plan to build a timber deck beneath it. We’ve looked at composite - but don’t really like it. Given it’s the end of a nine month build, the old bank balance is not what it used to be! My questions are: What timber would you recommend for a long lasting deck that will look good and be a reasonable maintenance proposition? Any advice on sub-structure to ensure a long life etc? Once it’s built, what preservative should I use which will look natural and be effective? Thanks for your help, W
  4. Hi, Screed is down and dying out. I have wet UFH in 50mm of anhydrate screed. I plan to use engineered timber flooring. I’ve had the screed sanded to address laitence etc. The question I have is whether to lay underlay, or bond directly to the screed. I have been advised that underlay will impair the efficiency of the UFH? I’d appreciate your advice please? Thx
  5. Hi, Can anyone recommend an inexpensive moisture meter which I can use to test the liquid screed floor so I know it's ok to lay the engineered timber floor? I have seen a Tilemaster hygrometer - but would be good to know if it's any good before buying? Any recommendations please? Is it t the sort of thing that you can hire? Thx
  6. Hi, That's interesting - I hadn't really considered the heat transfer would be impaired by the underlay?
  7. Hi, I’m having liquid screed poured next week. Build-up is: Block & beam floor 1200g DPM 150mm insulation 1200g DPM UFH 50mm liquid screed Any thoughts on drying time before it would be safe to lay underlay and an engineered timber floor? Is it worth running a dehumidifier for a few days? Any insight would be really helpful. Thanks, W
  8. Thanks all - very helpful!
  9. Hi, I’m installing wet UFH over a new block & beam concrete floor. I need some advice on: The best material to act as a membrane over the block & beam before I lay the insulation layer? The best membrane to lay over the UFH once clipped to the insulation before we pour the liquid screed. Best product to go over the screed (once laitance has been taken care of, before laying engineered wood floor. I’d really appreciate some advice and recommendations please? Thanks v m, W
  10. Hi, Id like some advice on pipe lagging for the rad circuit with a heat pump. Just had all new pipe work including a 28mm rad circuit. House is very well insulated. My question is what is the best / most sensible lagging approach for the rad circuit to minimise heat loss and protect against issues? I was thinking of using 13mm self sealing lagging and then wrapping with rock wool? Grateful for any ideas / thoughts please? Thanks!
  11. BotusBuild! Thanks for the recommendation. I've been in contact with them and they have been great so far - very helpful and the quote is good too! I was impressed with the information which they send over with the quote too - really informative and gives me faith. Thanks for the recommendation.
  12. What I was getting at is whether a liquid screed will warm more quickly, hold heat better etc?
  13. HI all, I have a reasonably large area to screed over UFH. The pricing for liquid screed seems to be pretty good - only a few hundred more than concrete. I like this as an idea, especially if I don't have to do it, it's more thermally efficient for UFH and it dries and is walkable faster than concrete. It all seems great - but is there anything that I need to be aware of before I commit? Does anyone have any recommendations for a supplier in the South West - I'm in Porlock, Somerset. Thanks for your help, Sean
  14. Hi, Any advice on the best products to provide UV protection for thermo wood cladding? I’m looking for a brushable clear UV coating that will help to slow the weathering / greying of my cladding. Has anyone got any personal use recommendations? t Thanks v m, W
  15. Hi, I’m in the latter stage of finishing a new roof. I could use some advice on insulation and cavity size. I am able to get 150mm of insulation between the rafters and then plaster board, leaving a 25mm air cavity. My questions are: Will this be ok from a building regs point of view? Will it be sufficiently thermally effective? Any thoughts please? Thanks v m,
  16. Hi, I'm doing a major refurb and switching to an ASHP. I've insulated the walls to within an inch of their lives but now just getting the new roof felt & battened. I need to insulate the crawl spaces in the loft area and now is the time where I have the best access. I have removed all the old fibreglass insulation and want to replace with something that is thermally efficient and won't cause me to itch as much as the fibre glass. What would people recommend that is efficient and easy to install. What depth of insulation should I be aiming for in the loft spaces? Any help much appreciated. Thanks, W
  17. Hi, Thanks for the suggestion but as the areas are a series of small-ish spaces I might not get the heat output that will be needed? Appreciate that I don't need the utility room etc to be roasting but think a series of short runs might not be terribly effective? Thx W
  18. Hi all, I am doing a major refurb and had planned to use wet underfloor heating to the new build kitchen / sitting / dining area. I've factored in floor height to accommodate this. On reflection, I think it would be great to extend the underfloor to the adjacent utility, bathroom and hall areas. The problem is that this area is existing and is a timber board floor. I'm reluctant to have to make major alterations to the floor height in this area - but it would be great to avoid using radiators. I understand there are mesh type / thin profile electric underfloor systems - which would minimise the extra work and hassle. My questions are: Is electric underfloor reasonably economical to run (we'll have solar and battery etc) These areas will need background warmth only. Are the mesh / thin profile systems an option for this type of application? Is the existing floor board floor a problem - what would I need to do to this to make the approach effective? I'd really appreciate some help with this - really outside my comfort zone. Thanks, Sean
  19. Hi, Does anyone have any experience of True Glide based in Sheffield. I've been impressed with the quote and service so far - but would like to know if anyone has used them and would recommend them please? Thanks W
  20. Walshie
    Cladding
    Hi all, Does anyone have any experience of QTD timber in Reading? I've got some sample of their heat treated cladding which I like, but I'd like to know if anyone has any experience / knowledge of the company and theirproducts please? Thanks for your help, W
  21. Hi, Does anyone have any direct experience of Cortizo windows and doors? I have a good quote for supply but would be more comfortable if I had some feedback from you wise people? Thanks, W
  22. Hi, I'm planning and refurb and was thinking about building an external 'services' cupboard to house electricity meter, solar controls and battery. The plan is to build a timber double skinned fully insulated (50mm PIR board) cupboard which will then be clad in timber. If I have the battery sitting in there - am I likely to run into any little nasties that will come to bite me? Thanks for your help, W
  23. Hi, I'd like to get some recommendations for a good supplier installer in the South West (I'm in West Somerset). Ideally a supplier that can design, supply and install solar and and ASHP. I'd be grateful for any recommendation please? Thanks W
  24. Hi, Quite a few places advertise it but when you get as far as placing an order they can't fulfill. I have got a couple of places that do seem to be able to supply - but I suppose I won't really know until order is placed. I'm looking at the beads option too.
