JBASport
Everything posted by JBASport
  1. Thanks for that advice. Terry
  2. I can get an edge up but you can see that if I tried to lift it any further the board will start to crack. I have tried heat, but that seem to work either. Although under cover in an open extension I think it must have been a damp environment that caused the sheets to stick together. Terry
  3. A delay in funding for the project meant a significant delay in commencement. We had about 40 Sheets of foiled backed plasterboard stacked, foil against foil. We are not sure what has happened but the sheets are stuck together 2 at a time, foil to foil. Is there a way we can separate them without causing damage to the sheets? Thankyou in advance for any advice. Terry
  4. I have an old property with a bespoke stone fireplace with a coal basket used to burn a combination of wood & coal. I plan on fitting a dedicated log/wood burning stove. However without modifying the stone chimney, there is not enough space to install the new stove directly under the flue, so will have to locate it in front of the opening and connect the flue through an angled connection. obviously I will extend the hearth to accommodate the extending location of the fire. I would welcome advice on who to connect the fire by either rear or top entry flue. Many thanks, Terry
  5. I have had some intermittent firing with my Paslode IM65 Nail Gun. I stripped it down and gave it a good clean & oiling. Before I completely reassembled it , I thought I would check the spark. I noticed that although it sparked on every trigger operation, sometimes the spark arced between the tip and the lug above it, but often the sparked would arc horizontally to the case. Is this normal only I cannot seem to find any detailed information on troubleshooting & sevicing Paslode Nail Guns. Thanks
