Triggaaar
Everything posted by Triggaaar
These are some of the units I'm looking at: The cheapest, at £222, not including any ducting etc. It's not as efficient as the units I've seen others here use, but I presume it's still better than just having trickle vents? https://www.bpcventilation.com/komfort-d105-a And then a few units for between £770 and £890 https://www.extractorfanworld.co.uk/domus-ventilation-hrxe-mvhr-unit-with-summer-bypass-4556-p.asp https://www.bpcventilation.com/airflow-duplexvent-bv400 https://www.bpcventilation.com/silavent-hrxd https://www.bpcventilation.com/vent-axia-integra Some of these can do more than one room, should I wish to add to the system later. Has anyone got any experience of any of these brands, and any recommendations?
Thank you for the reply, it's much appreciated. I was thinking of a unit that had separate holes in the wall, as you suggest. I was thinking of something like this: https://www.bpcventilation.com/komfort-d105-a and not something like this: https://www.bpcventilation.com/vent-axia-tempra-htp I hadn't thought of just getting a bigger unit and only using two of the connections (1 in, 1 out), so I'll consider that too, thanks. Although I'd like to do as you suggest, and have the extract by the cooking area, and the inlet in the living area, I have an ideal location for the unit in the adjacent utility room, but much of the extension will be cut off from it by large supporting steels (supporting the room above). I can have an extract by the kitchen cooking area, and an inlet 4.5m away, nearer the entrance to the room (the entrance is a few metres after the door). It's not ideal, but I think I have to accept that I can't have the ideal situation, but rather I can hope to achieve something that's better than just having trickle vents in the room. Given that I don't think my situation is ideal, I don't want to spend too much on the unit. I'm hoping for something fairly basic, that does a reasonable job, and hopefully lasts well enough. Are there any actual units anyone could recommend?
Hi all I've been building a single story extension, which has enlarged our kitchen into an open plan kitchen/living/diner of about 70m2. The rest of the house is 100 years old, so fairly leaky (I have reduced some leaks, but I haven't been attempting to make it airtight). The room has no windows, but has large glass sliding doors (6.7m x 2.7m). These do not have trickle vents. From reading on here I think the airflow calculation I need to do is internal floor area * 0.3 l/s/m2. So 70 * 0.3 = 21 l/s = 75.6 m3/hr. The building control notes I've received say: Part F 1. Provide 5000mm2 background/trickle ventilation per habitable room and 2500mm2 to kitchen. 2. Provide mechanical ventilation in the Kitchen at a rate of 60 l/s or 30 l/s via a cooker hood. I'm hoping I can replace 1. (the trickle ventilation) with MVHR. I'm planning to have the cooker hood on circulate (just to remove the grease), and hoping point 2 is also covered by the MVHR. Could anyone advice is I'm on track with the 75.6m3 calculation, and what single room unit would be suitable? I'd like to DIY install, putting the unit above the false ceiling in the utility room, and running an inlet and outlet pipe over the new kitchen. Many thanks
Bump. I'd like to have a single room MVHR solution and I'll soon be doing the wiring, so need to decide where the inlet and extract for the MVHR go. Recommendations for the make and model of MVHR would also be much appreciated. Thanks
New Kitchen/Living extension. Brick & block or brick and timber?
Triggaaar replied to Triggaaar's topic in Brick & Block
Cool, thank you. I'll assume that can go between lightweight block and the PIR that the plasterboard is stuck to. -
Thank you. I'll start by getting a price comparison from my suppliers. If it is 25% more, then I'll definitely go for separates. Sorry, I don't know what foam bonding is? -
Hi Peter One of my builders suggested I use 25mm PIR bonded to plasterboard, and dot & dab it onto our lightweight blocks, instead of fitting the PIR between battens. That way there won't be thermal breaks in the PIR. Why have you gone for battens instead of the method he suggested? Thanks -
Although I know close to nothing about MVHR, I was thinking of having it. We have no trickle vents for the room, so I thought about a single room solution. I'd also consider a solution for the whole house, but I've had a brief look at other threads, which mainly highlight just how little I know about it all. I mentioned MVHR as a solution to the BCO and he started asking me questions I don't yet know. Does a single room MVHR usually have separate inlets and extracts, or are they sometimes together? Is the MVHR constantly on, or does it switch on when it detects the need, or what? Thanks
What if you change the extractor to re-circulate the air, instead of extract it?
Thank you. We'll have a direct external air supply straight into the burner. BCO is happy so far, but then he's not the one fitting it. Mmm. We're presumably not the first people to have a log burner in an open plan kitchen - how do people usually get around this issue? Thanks
Thank you all for the replies. I have no idea what the solution is.
Full Fill Cavity insulation. 0.036 vs 0.032
Triggaaar replied to Triggaaar's topic in Heat Insulation
Oops, yes, that was a typo. Thanks. Yes, I had actually thought about boiler inefficiency, but thought I'd let it go So if the heating was required to keep the room warm all year, then I could be saving about £2. But then the heating won't even used for half the year, so I'd be lucky to save £1. In other words, don't bother going for the 0.032 over the cheaper 0.036. How about the floor and roof insulation? I'm currently planning on 100mm floor, and 140mm roof (PIR 0.022). Is there much point in increasing either? Many thanks -
Thank you both for the replies, much appreciated. I assume the 0.036 is 12.5% better than 0.032. It costs 81% more. But that percentage wouldn't mean a lot if it was cheap to start with. For that one wall, we're talking £70 more. Thanks. You clearly have the answer I'm looking for - now I just need to try and understand it The wall areas I'm taking about total 55m2. So you're saying it would be 55kWh / year. Do I just times that by the cost of our gas (say 3p/kwh) to get a yearly saving of £1.65? -
We've just started our kitchen extension (foundations completed, brick and block about to start). The finished room will 7.5m wide x 9.6m long, 2.7m high (internal). The east elevation will be mostly glass sliding doors. to the garden. The south elevation will be brick & block with 150mm full fill cavity. Inside that we'll have 25mm PIR in between battens, and then plasterboard and wet plaster. The blocks are Celcon, with a thermal conductivity of 0.15W/mK. Half of the north elevation will be the existing walls, which are brick and brick, with 100mm cavity, which was filled some years ago with beads. The other half will be new brick and block with 100mm full fill cavity. Again with 25mm inside. The west then joins the rest of the old Edwardian house. The plan is to have a concrete oversite (on top of hardcore) and then 100mm of PIR rated at 0.022W/mK, and a warm roof with 140mm of the same PIR. Do those thicknesses sound alright? I know we'll meet building regs, but I don't know if it's worth doing any more. Re the cavities, do you think it'll make much difference whether the 100mm cavity wall insulation is 0.036W/mK or 0.032W/mK? Since the insulation is thinner than the opposite wall, I wondered whether it would be worth putting a slightly better insulation in. It's not much more expensive, but then the difference might be so negligible it's still not worth it. Thanks
We've just started our kitchen extension (foundations completed, brick and block about to start). The finished room will 7.5m wide x 9.6m long, 2.7m high (internal). The east elevation will be mostly glass sliding doors. to the garden. The north and south elevations will be brick & block with full fill cavity. The west then joins the rest of the old Edwardian house. There will be underfloor heating on top of PIR insulation on top of the concrete oversite. We'll have a new warm flat roof, with 1 largish rooflight, with solar restricting glass. The will be a new log burner, which might only be 5kw. We currently have no ventilation plan at all (other than an extractor fan in the kitchen, which will exhaust straight out the wall). The glass doors will not have trickle vents. What would you guys suggest as possible solutions? Many thanks
Well the build has started. I've finished the foundations, and the blocks and bricks start on Thursday. Without a recommended company for the blown beads, we just decided to go for full fill cavities with glass mineral wool. 150mm on one wall, 100mm on the other, with PIR on the inside. The inner blocks are Celcon, with a thermal conductivity of 0.15W/mK. I know some go for more thermal mass inside, with more insulation outside, but the Celcons are what my building regs guy specked, and it should make the room heat more quickly from cold. The plan is to have a concrete oversite (on top of hardcore) and then 100mm of PIR rated at 0.022W/mK, and a warm roof with 140mm of the same PIR. Do those thicknesses sound alright? I know we'll meet building regs, but I don't know if it's worth doing any more. Re the cavities, do you think it'll make much difference whether the 100mm cavity wall insulation is 0.036W/mK or 0.032W/mK? Since the insulation is thinner than the opposite wall, I wondered whether it would be worth putting a slightly better insulation in. It's not much more expensive, but then the difference might be so negligible it's still not worth it. Thanks -
Am I allowed to post links to Houzz? I just found the example below of an open plan kitchen with lots of glazing. They have roller blinds without a box, and they don't seem to detract from the look of the room at all. I think the reasons it works are that the floor, walls, ceiling and blind are all white or off-white, and the glass doors have a very slim frame around it. I don't think I'll be able to get such slim door frames (due to budget, as they're such large doors), but maybe we can come up with a solution: https://www.houzz.co.uk/photos/1950s-residential-transformation-contemporary-dining-room-phvw-vp~129829757
Thank you so much for doing those, much appreciated. Any idea what model the lights are, or what wattage they are etc? Thanks
Yeah this is my concern. Although it's at the back of the house, I imagine it's not a comfortable feel. I'd like to see what it's like with some subtle outside lighting though.
Thank you. I like this solution and wouldn't mind giving it a go. You can't really test it at this time of year, but I wonder how it would feel in winter if you switched the outside lights off?
I put the reasons in the first post. Yes, that's my concern with having roller blind boxes in front of them. It's not that I think they frames will look good (we're not going to go for the ultra slim ones), but that I think the overall look would be a little spoiled with blinds there (during the day, when the blinds are up). This is for a kitchen extension, so it will also be modern. I'm not worried about the look when it's daylight, only when it's dark outside at like 5/6pm. I was thinking of a row of spotlights in the roof that overhangs the door, but I hadn't thought of lights inside, and certainly not thought of lighting them from below. What lights have you used, what flooring are they in, and how would you describe the look? Sounds like something with light could be a good option. Thanks for the suggestions
Sorry, my mistake, I thought the link in your first post was to a post of yours. The price there was £1k/m, and that was for fixed glass, not sliding doors. So for 7m x 2.75m, only £20k, plus dealing with the fact the doors move. Yeah, nice as it would be, that's just not going to happen
Thanks for the photos, really helpful! If we went for a thin curtain like that, I think I'd want the flush curtain rail, rather than a cable. We could put it in front of the doors, which would give 25cm of space either side (total room width 7.5m).
Do you know of sliding door manufacturers that offer SageGlass?
