So we currently have a decent condensing boiler which we picked to have extra ‘welly’ in case we ever added a second bathroom. Well we’ve gone a bit further than that and built a large L-shaped wrap around ICF extension. The current boiler can easily service 2 bathrooms that will be above it, without moving it or adding much extra pipe work.
However, our en-suite, the kitchen and the manifold for the UFH are at the side of the extension, about as far away as you can get from the existing pipe work.
we are wondering if it wouldn’t be simpler to add a second condensing boiler in the new kitchen for the en-suite and UFH.
This would take up way less space than a system boiler, and would be relatively easy to get the gas to it and much simpler pipe work. I think the cost would even out with the labour bill being lower.
We will have a highly insulated and airtight house when done, so the demand for space heating should be low. We’ve ruled out an air source heat pump for now (and realise we are possibly ruling one out forever if we don’t put the pipe work in for a single central point now when everything is easy to get to).
Just after views as to whether this is a ridiculous idea or not?
