WannabeBob
Personal Information
Location
Cambridgeshire
WannabeBob's Achievements
Member (3/5)
11
UFH in the bathroom - wet system or electric?
WannabeBob replied to Great_scot_selfbuild's topic in Underfloor Heating
We are doing exactly this, with wet UFH downstairs and only electric resistive (towel rail and bathroom) upstairs. It should be very quick to heat up so I don’t think will take too much power to run especially if it only comes on at specific times of the day and on a sensor when we detect presence. However… that’s still the theory and we are still building so I suppose I can’t say yet that all of that will work! We are at <10W/m2 though so can’t comment about that yet -
Rebar suppliers that can do 90mm h10 links?
WannabeBob replied to WannabeBob's topic in General Structural Issues
Thanks. Yes, we’ve checked the dimensions with them and according to our SE that’s the “standard detail” approved by the ICF manufacturer who’ll come on site to help with the first lift as well. -
Happy days, I’ve managed to find a supplier to do the links in 90mm without any extra costs. Thanks all for the help. I won’t be needing the jig after all. -
Thanks. If you’re happy to sell it I’ll let you know on Tuesday if we decide to try it ourselves. -
Let’s just say I won’t be recommending them for many other reasons as well. We’re thinking of trying it out with a bending jig as a trial and see how feasible it is -
Which bender did you get? -
Although for the price of a takeaway, this might by worth trying https://www.aliexpress.com/item/1005005983014134.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.1.17deBXtBBXtB3z&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=591a7a8e-a5b9-4053-b294-7087714f343d&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:591a7a8e-a5b9-4053-b294-7087714f343d,tpp_buckets:668%232846%238116%232002&pdp_ext_f={"order"%3A"43"%2C"eval"%3A"1"%2C"sceneId"%3A"30050"}&pdp_npi=4%40dis!GBP!12.73!8.83!!!119.38!82.80!%402103891017449243290116801e4967!12000035171723357!rec!UK!!ABXZ&utparam-url=scene%3ApcDetailTopMoreOtherSeller|query_from%3A -
I might spend more time making a jig than bending bars! -
Thanks Russell! Yes we can drop to H8 as well, though with the ones I’ve checked with was still 100 or 110. Yeah. We don’t have crazy amount and it’s pretty much straight bars or square links but I’d still rather avoid bending them on site if I can -
Maybe I’m being a bit uppity about it, but how do you know if the rebar meets the standards? I’m assuming that’s why most suppliers can’t go down to 90mm either. -
Hey folks, me again! Our swimming pool foundation dig is going well so far. I was wondering if anyone can recommend any rebar suppliers that can do H10 (10mm) links/stirrups with a dimension of 90mm, ie shape code 51 where B=90mm Our engineers have specified 90mm max for our lintels and piers as they want a 30mm coverage each side within our 150mm ICF concrete due to fire regulations. The suppliers I’ve checked with say they can only do down to 100mm, some even only going down to 110mm. I did get a quote from someone that said they could do it, at 20% more expensive and of dubious repute? I say dubious but really it’s just that I haven’t seen them mentioned before, and hoping someone here might have personal recommendations instead. I’ve asked our engineers to come up with alternatives but I’m not very optimistic about them coming up with a timely solution… I’d rather get the bars supplied bent, but failing that how hard is it to bend my own bars for a pencil neck with absolutely no experience? 😅 Thanks!
Insulated threshold detail for insulated rafts
WannabeBob replied to WannabeBob's topic in General Construction Issues
Thanks, that sounds like it might be the way to go about it then. Yeah we are doing that for the ground floor wetroom too, but wasn’t too sure if this being at the edge would cause issues. It sounds like i’m worrying too much about that though. -
I suspect if push came to shove we’d be able to do that, but just exploring options at this point Right, the doors themselves are only going to be installed much later when the walls and roof is up. It’s only the threshold/upstand that might get installed during the concrete pour. The doors then sit on those upstands. I get the mechanics of shuttering then filling in the void, but won’t this create a section that isn’t bonded together as well as a continuous pour? Or does it not matter really?
