Hi All,
Having an issue with the AI setting in Auto mode for heating. I set the min-max temp and everything seems fine during the late evening/night. In the late morning if the sun is out it is heating the outside unit and the OAT sensor reads about 5c more than the real outside temp and the heat pump lowers the LWT according the the "false" reading. I am wondering if the sun is heating the metal panels of the heat pump so the sensor is reading the wrong temp. If this is possible, can the sensor be moved to the area between the wall and heat pump where there is always shade?
