Jakeb
Everything posted by Jakeb
  1. ill need to check the zone valve, ill let you know. but yea when heat is required zone valve will open allwoing boiler to fire up.
  2. @Nickfromwales any advice mate?
  3. Good Day Team, Im a plumber gas fitter from New Zealand and have been ask to install pipe work from a boiler to underfloor heating manifold, i just want to assure ive got this correct before i proceed. The manifold has been installed by others and ive supplied the boiler. They have left behind the wiring centre, 2 thermostats, 1 zone valve and the actuators. System only 13 KW electric boiler supplying a 2 zone underfloor heating manifold, if someone could confirm the valving is correct that would be appreciated. Do i need a automatic by pass valve or is a standard gate valve in the open postistion okay? Ive attached a rough sketch some advice would be appreciated. Usaully the supplier would give me all this info but i cannot get that from the supplier here (not very helpful). Cheers UFH draft.pdf
