Shane Adcock
Everything posted by Shane Adcock
  1. Thank you for the advice, I think I will go without the fibre as I’ve laid plenty of normal pads without fibre but never any with fibre and would rather no have my first one being such a big pour encase it goes wrong and just put two layers of steel into the pad and use an RC45 mix. As for drainage slopes, I was going to aim for about 10-12mm per meter which may still be a little too much as its got to have a single course of bricks put around where the stable will sit and don’t want it to far out of level for that. As for the control joints I would normally put them about 30x the thickness as that’s what I was taught but, in this case, to make cleaning the stables easier I am aiming to put them under the separator walls (unless there is a reason I shouldn’t do that?). everything that is going to take a fair bit of weight that I have laid in the past has come with a design drawing but apparently these stables don’t which is why I am asking for a little advice to make sure I get it correct.
  2. Shane Adcock
    Concrete
    Hi all, I am just pricing a stable base and am considering using concrete with fibre in and was wondering if I would still need to use steel reinforcing with it if I did, normally we just use steel reinforcing with an RC45 at 150mm thick. Also does anyone know of a spec sheet that will tell me recommended thickness and requirements for different load bearings. Thank you for any help and advice.
