Danzka
Everything posted by Danzka
Yes, something to deflect oily/greasy stuff - cheers...
- 35 replies
- pointing
- recessed pointing
Hmm, you (and helpful others) have helped solidify what would look best, so thanks for that. Just need to make up my own mind whether I like a shallow (brush) or recessed (chariot) finish ?. Might be worth doing samples of each around the corner where it will be behind a cabinet and seeing which is personally preferable.
- 35 replies
- pointing
- recessed pointing
Yes, that is on the cards @Ferdinand. Not sure what I’m going to put on it yet, but I know clear brick sealer of some sort exists. Thanks for making sure this wasn’t missed.
- 35 replies
- pointing
- recessed pointing
Appreciate the feedback @Mr Punter, does recessed work as a style with uneven bricks or is it more intended for modern, evenly sized bricks?
- 35 replies
- pointing
- recessed pointing
I like it, saves me buying a chariot and negotiating around all the odd shaped bricks as a bonus. I like the idea of recessed, but all the odd shaped bricks make me wonder if it works work or not. Thanks for taking the time to lend me your experience @Declan52, appreciate it.
- 35 replies
- pointing
- recessed pointing
Yes, I get 60 minutes. That’s looks nice, so the brushing kind of recesses it a bit and the sponging smoothes out the brush marks - is that the idea?
- 35 replies
- pointing
- recessed pointing
This is inside the house so weatherproofing is not an issue, see pic. Is it correct that recessed highlights the bricks more than bucket?
- 35 replies
- pointing
- recessed pointing
Cheers ?
- 35 replies
- pointing
- recessed pointing
Unfortunately no, good idea though... did you have any trouble with the irregular shape of them?
- 35 replies
- pointing
- recessed pointing
I don’t think I’m good enough to do that ?. If you had to choose between bucket or recessed, which would you recommend?
- 35 replies
- pointing
- recessed pointing
That actually covers another query I had thanks Declan52, how best to finish it? How do you reliably tell when it’s near set? Just poke a test bit you have set aside from the mix?
- 35 replies
- pointing
- recessed pointing
Yes, I am, just not sure which pointing style to go for...what do you think would work/look best? I’ve heard recessed highlights the bricks more?
- 35 replies
- pointing
- recessed pointing
The brick slips are 20mm thick and would do a 5mm recess, other companies sell 15mm brick slips so there should still be enough...?
- 35 replies
- pointing
- recessed pointing
Thanks for responding, this is a feature wall as part of the living/kitchen/dining area - so it will be real up-and-close as the island is about 1m from it...
- 35 replies
- pointing
- recessed pointing
Hi everyone, just seeking advice on what pointing style would be best suited to Olde Water Mill style brick slips? They’re quite irregularly shaped, see pics... I’m thinking of either recessed or bucket, leaning towards recessed, but have read that is best suited to more modern sharper shaped bricks???
- 35 replies
- pointing
- recessed pointing
Hi everyone, I’m wondering whether to finish my brick slips (called Old Water Mill) in bucket or recessed pointing. They are an old style and very irregularly shaped (see pic), what style would lend itself best to these bricks? Many thanks.
- 35 replies
- pointing
- recessed pointing
