slystallone
Everything posted by slystallone
  1. Tried it but none of the keys fit
  2. Is anyone familiar with this types of shower rail brackets for holding the rail upon which the shower head holder slides up and down on and how to remove these? I could just get a drill I guess to get at the screw underneath, however as can be seen below there is a hole of some sort, which appears not to have a screw head that I can see and maybe it can be removed in an easier way then just drilling through it.Any advice would be greatly appreciated
  3. Where are you suggesting the new trench? On top of the wall underneath the outlet?
  4. It's my land. 500 to get someone to do it? Also on your last point about joining up outlet pipes, how do you recommend to do that?
  5. Can you give more details on what that drainage would look like behind the wall please?
  6. Ya there is no movement
  7. What kind of drainage would be behind the wall if it was done in the way you mention rather than through the wall?
  8. If water gushes out I am in serious trouble no? Who would be right type of tradesman to call to suss this out?
  9. It is a retaining wall as the land behind the house is very steep so it is supporting a cutout
  10. How would you sort the cracks that have appeared,for example, under the outlet in the picture here
  11. What do you mean by beds?
  12. Thanks, ok it sounds like I need to sort the drainage on the hill above the drain as recently it is like a non stop torrent coming out of it and making the place look a mess as can be seen in picture. I know we have had a lot of rain lately but can't be looking at that much longer. Also I have added another picture where I have outlet pipes in the middle of retaining wall itself. Is that also for getting rid of excess water behind the wall?
  13. I have the 3 inch pipe that drains to nowhere in the patio above my house that I bought. There is a drain pipe near by to the right of the pipe on the photo but wondering what would be the best way to attach a pipe to this wall without having any leaks where the wall meets the pipe?
  14. How hard would it be to move / rotate the stove in this picture ? Moved into a house but in my opinion the stove is not at optimum position because it is facing away from where people are sitting. My ideal situaution would be to have the stove to the left of the television, facing in the same direction as the television.
