harrison247
Everything posted by harrison247
  1. True, however the only "plan" in the lease is not a room-by-room floorplan but rather a plan of the exterior boundary walls, as per the definition below. So this is perhaps further support that the license to alter is aimed more at extensions than alterations involving internal walls? My bathroom refurbishment certainly wouldn't change the lease plan at all A lease plan defines the boundaries and areas included in a lease, while a floor plan shows the layout and dimensions of the property's interior.
  2. Okay, so I what I am now considering is adjusting the layout plan, attached. (Current layout on the left, potential new layout on the right.) This should not require license to alter, according to the rules of the lease. This would involve: 1. Confirming with a surveyor that the coat room walls are indeed not bearing, and removing those internal walls to increase the floorspace. 2. Leaving the toilet in the top left of the room and putting the sink in the top right, which should mean that no new pipes need to be fitted through the exterior (bearing) wall. (The sink and bath can both feed into the current bath wastewater pipe.) If I do this, my inclination would be not to inform the freeholder, as I do not believe I would need to do so under the lease (which only says altering bearing walls needs a license); if I did tell them, the worst case is that they could dispute it or say that that if I want any form of written consent then there will still be a charge. But, when eventually selling the property, I would then need to state in the sale docs that works had been done in the property - in this situation it would be preferable to have some form of consent from the freeholder in case the buyer's solicitor questions this. Or am I over-thinking it? If the alteration is not prohibited by the lease and I have all the appropriate construction/surveyor documentation, surely that is enough for the buyer? Plan B.pdf
  3. Thanks Joe. Yes, I could approach the freeholder to prove that that interior coat room wall (change 3) is not bearing. But if I confirm (e.g. with a surveyor) that it isn't bearing, then I guess that according to the lease I have no need to get consent/license from the freeholder to alter it. (Note that the "plan" of the maisonette in the lease is not an internal floor plan, it only shows the plan of the exterior walls.) FYI I am the leaseholder, and the "lessor" who grants the license is the freeholder.
  4. Hi all, first-time poster here! My partner and I bought our first home last year, a long-lease maisonette, and we now hope to refurbish the bathroom. The alteration section of the lease reads as follows: (13) Not at any time during the said term without the license in writing of the Lessor... to make any alteration in plan or elevation of the maisonette building hereby demised or in any of the party walls or the principal or bearing walls or timbers thereof... The key bit is that no alterations in load-bearing walls can be made without a license from the lessor (i.e. freeholder). The cost of this license (plus a surveyor visit plus admin) would be over £3k, according to the freeholder's fees. Considering the other costs and benefits, this extra cost would not make the "ideal refurbishment" worth doing. Our ideal refurbishment would involve 3 bits of work that relate to the walls. Installing an extractor fan in the exterior wall of the bathroom. (This is a bearing wall, but a vent/grill already exists on the outside.) Connecting the newly positioned toilet to the exterior soil pipe by passing this through the exterior wall. Removing the interior walls of a coat room adjacent to the bathroom. We understand from contractors that these walls are not load bearing, and would get a surveyor to confirm this. I feel points 1 and 3 are likely fine, no license needed, but point 2 is the one I am most unsure about. It depends on the definition of what constitutes an "alteration" to a wall: does creating a hole and feeding a new pipe through the wall count as an alteration, even if it doesn't change the overall size/look of the wall? (All works will be done by a suitably qualified contractor.) Surely it is quite common for people in leasehold properties to have holes drilled through exterior walls (e.g. for broadband cables or utilities), but is there no minimum threshold for what counts as an alteration? Any ideas or suggestions much appreciated!
