rah212
Personal Information
  • Location
    Wiltshire
rah212's Achievements
New Member
New Member (2/5)
0
  1. Good Evening everyone, Im hoping someone may be able to help me identify what type of cladding this is ? it is tongue and groove but im struggling to find what type of moulding it may be as I have to replace a few boards. If anyone has any suggestions or advice id really appreciate your time please. Hope you are all having a great weekend. many thanks in advance
  2. thank you very much for your reply
  3. Good afternoon Everyone, I hope you may be able to help please I have to replace a few of these slabs and im not too sure what they are exactly.. Maybe yorkstone slabs? This job is in salisbury Wiltshire whether that helps. Ive attached a couple pictures and one picture is of a small piece of the slabs. Really appreciate any advice, Many thanks in advance
  4. Hello everyone, Im hoping someone may be able to help me please, Can someone please advice what the highlighted bricks are many thanks in advance
  5. Hello everyone, I hope someone may be able to advise me please. A lady has asked me if I can lay 2.2m x 3.6m worth of chipboard flooring in her bungalow loft. Im thinking there may be too much weight on the joists as its a truss roof system ? Am I over thinking it? Possibly use loft legs instead of timbers to raise the flooring up 150mm to get over the double layer of insulation plus to save weight on the joists? Then lay 18mm 600 x 2400mm chipboard flooring on top ? I would really appreciate anyones time and advise. Many thanks in advance
  6. Hello everyone, I hope someone may be able to advise me please. A lady has asked me if I can lay 2.2m x 3.6m worth of chipboard flooring in her bungalow loft. Im thinking there may be too much weight on the joists as its a truss roof system ? Am I over thinking it? Possibly use loft legs instead of timbers to raise the flooring up 150mm to get over the double layer of insulation plus to save weight on the joists? Then lay 18mm 600 x 2400mm chipboard flooring on top ? I would really appreciate anyones time and advise. Many thanks in advance
  7. Hello everyone ! I am 30 and an eager learner, I am basically a multi tradesman focusing mostly on carpentry and have been for 7 years, every day is different. Question for you guys is what would you advice to repair the bottom of the pillar from rot. My thoughts would be prop and cut out the effected area.. Then ? It is just a porch flat roof above, No rooms or walls etc. Would really appreciate your time and look forward to hearing some good ideas, many thanks in advance
