Hi all, I am new here so hopefully posting in the right place and this is OK to ask.
We have recently had the following installed:
Mistubishi Ecodan R32 11.2kW
Mitsubishi FTC6 controller
Underfloor heating throughout (Heatmiser controlled)
The Mitsubishi cylinder is horizontally mounted in the loft as shown in the picture.
We are seeing a behaviour which our installer said should not happen and yet Mitsubishi claim is 'normal'. Every 2-4 hours, the ASHP will activate when there is no call for hot water or heating (and no legionella cycle). The Hot water calls appear to be normal and happen as expected.
We were told that the ASHP should only really come on at the moment when the hot water needs bringing back up to temp. This is clearly not the case and now the installer is backtracking following a call to Mitsubishi.
I've complied a full day of hourly traces into one image (attached) that shows these spikes in the form of flow and return temperatures spiking, then gradually dropping and then triggering to spike again when it hits around 25degC. On this trace you can also see a hot water call and the cylinder temp rising to the correct level. We also tested the heating last night so you can see some activity around that.
We can also hear that water is being pumped through the services in the wall on the internal side of the setup - not sure if it is requesting water or wasting water or both, but it is coming from where the mains connects into the ASHP setup and where the ASHP connects down to the UFH manifolds.
As a side note, we did have an L9 error as well but this has not returned and so we think it is not related.
The main issue is that the pumps and water movement in the loft is noisy enough to wake us in the night. We are very tired!
I am not convinced this is normal behaviour - if it is, then we have a major issue with constant noise through the night. The 2 other Ecodan users I know do not see this happening.
Any ideas or seen this behaviour before?
Thanks in advance
