AdaminCymru
Everything posted by AdaminCymru
Hmm, yes it can get pretty windy / heavy rain is not unusual. So far no leaks and we’ve had some very heavy rain in the past few months
It is between 15-16 degrees and crest planum duo tiles which can go down to 15 degrees.
Thanks so much for your reply. BC officer is apparently happy with the builders explanation, but I’m not, and certainly not since taking a closer look today.
I’ve Recent had an extension and new roof structure. The final balance has not yet been paid and building control cert not yet issued. The builder says the lead work and sealant here is acceptable. BC initially raised it but the builder had apparently reassured him that lead sealant had been used inside the chase and the exterior silicone is just ‘decorative’. He says the lead does not need to be dressed over the tiles as the plaster soakers lap up underneath and up the vertical wall. I’ve removed some of the silicone and theres clearing nothing behind, the lead can be removed with ease. Is this acceptable? It looks terrible to me
Non compliant outside drainage
AdaminCymru replied to AdaminCymru's topic in General Self Build & DIY Discussion
Thanks for your response. Yes plenty of written communication about drainage but none stating he would deviate from a basic / acceptable standard. We have a dedicated storm water sewer network and separate foul, which he knows about. It would have just meant more work for him to do the work properly. There may not be a straight answer to this question but perhaps a more succinct way of putting it would be: If a portion of work is completed within the estimated fee, and that work is below an acceptable standard objectively, and the contract states all work will meet such standards, can the tradesman demand more money to bring this work up to an acceptable standard? -
Hi all, 200k contract nearing completion, based on an estimate. To date, numerous extras have been added at highly inflated prices so I want to be careful and well informed on how I raise this All outside rainwater drainage has been connected directly to the foul drains despite the contract stating all work will comply with the build over agreement, building control and planning. The builder is due his final £10k payment soon. I’m aware that if the water board are ever called out in the future, I could be fined heavily for his decision to cut corners - there is an up to date cctv survey on file and I know there are two existing rain water gulleys which he has left unused. If I pull him up on this, can he revise his estimate at this stage and demand more £ to complete the drainage adequately? Or, can he not do this, as the work has also been completed but non compliant? We have had many discussions about drainage throughout and he’s always said rain water would be connected to the 2 existing rain water gulleys. He then went ahead and ignored this. thank you
Concrete tile over hang
AdaminCymru replied to AdaminCymru's topic in Lofts, Dormers & Loft Conversions
Thank you for the response. Not in a conservation area and the house is detached -
Correction, a 300mm ladder overhangs the gable, plus 100mm tile over hanging the end of the ladder. Dormer is therefore set in 350mm from the outside of the external skin on the gable wall -
I’m having a dormer loft extension at the moment and the existing roof structure includes a 400mm overhang with laddered rafters plus another 100mm tile overhang beyond this to the verge. The approved planning drawings indicate that the dormer cheek will sit 750mm from the verge, so taking into account the laddered rafter plus 100mm tile overhang, the dormer cheek was set to be 250mm in from the outside of the outer gable skin. The trimmers for the cheek have been formed, but my builder says that the 100mm tile overhang must be reduced to about 30-40mm once the roof is re-tiled, as we are having a continuous dry verge. Would this be an issue with planning? The cheek is still where it is meant to be, but the distance to the verge is reduced. I’ve asked if the 100mm overhang could be maintained and he says it can’t - any thoughts on whether this can be maintained once the roof is retiled? Thank you
Block and beam over ground beam
AdaminCymru replied to AdaminCymru's topic in General Construction Issues
Thank you Annker. Yes I appreciate perhaps I didn’t work my comments correctly. BCO is visiting on Monday and I’ve emailed the engineer. It really does not sound right to me so let’s see what they say. thank you again -
I would appreciate some insight on this. We are building a single story rear extension with a block and beam floor. There is a ground beam spanning the rear of the extension which has been meshed and encased in concrete. There is no foundation under this ground beam, it rests on a trench on one end, and a pad on the other. The external blockwork is not running straight along the beam, and as a result, on one end we only have 100mm of concrete encased beam left for the 150mm cavity and thermalite internal skin. The blockwork has been built square however the beam must not have been laid the same. I spoke with the builder after noticing it and he says it’s fine and the internal skin and 150mm cavity will be built off the block and beam that rests on this 100mm. Does this sound correct? unfortunately my building control drawings do not detail this.
Thank you. I am concerned that with the render option, as this is a retaining wall (lawn), we would have problems down the line with water damage to the render
I require a new retaining wall in the garden, 0.6m above ground level and 18 metres in length including a few slight bends. The current plan is to build from blocks and then clad with some form of stone cladding. Whilst in London I came across this and wondered whether it could work as an alternative, avoiding the need to clad, and offering integrated seating into the design. I imagine it would be easy to power wash and I wouldn't need to worry about damaging any cladding adhesive with this option. I have called around a few pre-cast concrete suppliers and none seem to be able to offer this. Does anyone have any suggestions on where I could look into this further? Am I crazy to think this might work out cheaper than building with blocks, cladding, and then sorting an integrated seating option? Any ideas welcome Thanks Adam
Hello I have plans for a cold roof on a loft extension. I believe cold roofs can be problematic with heat retention in warmer months. The rafters that are currently spec’d are 200x47mm and total cold roof thickness 342mm. I am wondering whether a warm roof could be a better option, but I do not want to compromise on head space. If my engineer agrees to say a 125x75mm rafter instead of 200x47mm, what is the minimum thickness warm roof we could achieve here? any input greatly appreciated
Coatings for ridge beam and more
Great, thanks. At least I’ll be better informed when negotiating with my builder with a comparable quote -
Do fabricators quote to both supply and fit? -
Well 90kg per section so not sure whether a crane is required or not. -
Thanks Nod, just to be clear, priced separately are all other works relating to the loft extension, this £5250 is just for supply and instal of the steel ridge -
I would be most grateful for some advice here re some additional costings during a project. I am the homeowner and appreciate that additional work is required: - supply and fit of a 152x152x30 (9m span) steel ridge beam in a loft. It can be spliced in 3 sections if preferred. There is an existing loft extension but after strip out we discovered there was no ridge beam so this has been spec’d by the engineer. My existing quote from the builder includes scaffolding and all other works related to the dormer construction. Priced £5250 inc vat. - Marley duo concrete roof tiles for a 55m2 pitched roof including re-felt and battons. New lead flashing, UPVC fascia, softfits and dry verge, guttering to this area only. Priced £12840 inc vat. again scaffolding already in place
Good morning all, I've got some plans drawn (not submitted) for some works we plan on doing to our new family home. The provisional estimates from builders and QS have come in higher than expected at around £250K (fully finished including supply and fitting of kitchen, bathrooms). We will need a contingency on top of this, plus any other finishing touches. My existing floor plans are below, and so are the proposed (adjustments below not included). Project is in Cardiff. We have made some small adjustments to the proposed plans to save a little: - Leave downstairs WC in same place, instead of re-locating into the existing garage - Extend front porch only, not the front of garage - Single large roof lantern about GF extension, instead of two large These are not huge cost savings but every little helps. For this project to go ahead, I need it finished in less than 200K - Am I far off to consider this possible? I am happy to source high quality used kitchens and bathrooms. The flooring throughout the existing ground floor is solid parquet that can just be restored, not replaced. In order to save further, I am thinking of taking on one of two approaches: - Fully project manage individual trades - Hybrid - get a general contractor to get us watertight in the GF extension and porch and then project manage the rest with individual trades Please could I have some thoughts on the project and whether a max finished figure of 200K is realistic? Annon proposed.pdf
With costs this high, I can’t see how any extension / renovation would be feasible in properties outside of very high value areas e.g London where the renovation:property value ratio would be much higher. I’ve got 2-3 builders to take a look so will see what sort of figures they come up with. thanks for your input
