rob1234
rob1234's Achievements
New Member
New Member (2/5)
0
  1. thank you for your replies, Ive already built the extension and the new joists are sitting on the original wall plate with the existing bungalow joists do i still need the flat plate to be 285mm plate on the steel or can it be 2 steels bolted together
  2. 11 Whitby Avenue drawings.pdf
  3. Hi Im removing the 225mm solid wall up to the wall plate and need steel calculation for the steel size the opening its 2300mm wide and Im thinking of doing a loft conversion after and its on the corner of the bungalow so ive been told i have to come in 600mm from internal wall does anyone have any drawings detailing how far in from the corners and wall plate detail that i can use as an example. Kind regards, Rob
