borozu
borozu's Achievements
New Member
New Member (2/5)
0
  1. Like I said it shouldn't be any problem with neighbour as he's ok. And yes it will be obscured glazed, non-opening. It's just to get more light on the stairs as it's a very dark corner in the house
  2. Thanks for the answer Ah so that's 72 means at the end of application number. Yes as I remember it's the year the house was built. Unfortunately no chance for Velux. I don't think trespassing will be a problem, neighbour is ok and on the other side of the house his antenna is above my yard And as joe90 said "The eves already do" trespass Ok guys so I think I will put window together with porch on planning application. Let's see what happens. Thanks @kandgmitchell for a hint about PD's removed when house was built.
  3. Hi, I have a small project in my mind. I would like to enlarge the porch (more than 3sq) and put a new window on side of my house. I contacted building control team and planning department. Let's start with building control answer: I've checked on gov websites and new window should fall under permitted development as it would be non-opening etc. (topic will be continued later in this post) Questions for you guys about the porch: 1. Do I really have to install doors separating porch from main building? As I have seen applications approved without them. Please go to: https://publicaccess.aylesburyvaledc.gov.uk/online-applications/search.do?action=simple and check for the application number "23/00338/APP". In documents section there are drawings - proposal is accepted without door between the porch and the main building. So as building control suggested I contacted planning department They replied: I guess they talk about my window plan? I can not see this application on the website and no idea what this application is. Maybe the previous owner made it. But anyway - my 2nd question for you guys is can I put the side window on the same application with the porch enlargment? Example sketch of window idea attached. Thanks.
  4. Hi, I'm located in Bucks, I've registered to get advices on enlargement of my porch and eventual future advices on self build and that's my future dream. Hopefully I'll get everything sorted and share the info with you about the progress :)
