Hello,
After a quick sense check.
My house has a fairly heavy slope running down hill from the house.
The builders I believe put in place two retaining walls - I say I believe as the house was built in the 90s, and I bought sometime well after that. One near the house to facilitate the construction of the house and to provide a bit of flat space at ground level where the house is. The second wall at the bottom of the garden (and therefore bottom of the slope) to basically create some sort of termination at the bottom. The gardens in the next cul de sac down therefore have gardens at a far lower level to mine. I can see into theirs and vice versa.
If I run a bog standard 2m garden fence around the entire garden boundary, for the section at the bottom in the area where the second retaining wall is, as long as I do not exceed 2m from my ground level behind the retaining wall, there would presumably be no planning considerations?
I appreciate this is a small potatoes query given some of the other questions on here, but the neighbours at the bottom are comprehensive NIMBYS!
Thanks!
