I take the point that I can't say with authority until a formal test has been done. All apart from the Aga are against inside walls in old fireplaces. Hence my assumption that increased air supply would require holes in walls. Only one is in a room with a ground level suspended floor which could be vented. Apart from the size and leakiness of the house, the other reason for my assumption that we are not nearly at risk of insufficient air supply is that all three fires were installed by a meticulous gas engineer who did not raise the question of additional venting and have been regularly serviced by gas engineers.
The messages I take away are:-
1. As we continue on the journey of dealing with draughts etc, I need to pause when significant change has been made and recheck the adequacy of air supply to the appliances.
2. That journey strengthens the case for CO alarms.
3. That having an open flue appliance working in a room may (should?) contribute to increasing air leaks elsewhere in the house and make those areas cooler.
4. And so a longer term aim might be to find alternative ways of achieving individual room heating - ?smart TRVs, electric heaters, directing insulation efforts to rooms where the ambition is to remove a gas appliance.
Does that sound about right? And are others further down this journey in an old large and expensive to heat house and have solutions/experience to share?
