ringpull
ringpull's Achievements
New Member
New Member (2/5)
0
  1. Hi, cylinders are outside on an exterior wall with the ground sloping away from the house. Fitted to current standards in terms of distance from drains, windows etc. I do want to put a detector in the roof space under the boiler where any LPG will pool if there's a leak, but I can't find one where the sensor is on a cable away from the siren - the idea was not to have the siren in the roof where it might be muffled. Cheers Richard
  2. Hi, new to this forum as I'm looking for help on a subject my plumber seems woefully ill educated on. I've had a new LPG boiler fitted in my attic in a bungalow (no space elsewhere and convenient for the only location I can put the cylinders). The attic is reasonably well vented but do I need to fit an LPG detector in case there's a leak? I understand LPG is more dense than air and in this case any escaped gasses will vent through the loft hatch into the corridor. Should I fit a detector directly under the boiler in the attic? Ideally I'd like one with a remote sensor (wired is fine) as I can put the alarm in the corridor and the sensor in the attic. Regards Richard
