Hi all.
I have recently bought a Victorian house, and am coming to learn its various foibles!
One of them has been a basement (full footing of the house), which generally sits at 8degrees. On the whole, the temp of the exposed floorboards of the Ground Floor is 1.5 to 2degrees colder than the temp of the air at waist height in the same room. The cold convection makes it feel like there's a very cold draught coming up under your legs when sitting down on an evening.
The basement ceiling had zero insulation when I bought it, but I am in the process of installing:
100mm PIR board
80mm Batt insulation
Vapour Barrier membrane (2 way breathable)
It comes to about an 8 R Value. Whilst I know this will 'help' in terms of extra insulation, and removing draughts/air moisture, I am trying to find a calculation on whether this will stop the afore-mentioned cold transfer.
Basically, is there a way of seeing if an 8R Value ceiling is enough to stop an 8degree basement making an 18degree ground floor from feeling cold?
Thanks!
