Paul101
Everything posted by Paul101
  1. No, it will be a normal staircase from the ground floor to the first floor. I am planning to convert the first floor to a flat and then I need to give a staircase. I need to create door from the ground floor area of the external wall to inside and then the staircase. That is why I am looking for the cost. Thanks,
  2. Hi, I need to create a doorway from the ground floor external side wall of a commercial property to the first floor (residential). I assume I have to do the following: 1. Create an opening from the ground floor external wall with lintle and door 2. Create an opening on joists of the first floor to install the staircase from inside ground floor to the first floor 3. Install staircase from inside ground floor to the first floor I was wondering how much it will cost to do the entire job. Thanks
  3. I believe it is already installed as it is part of a shop - customers are shopping both in the ground floor and first now.
  4. Thanks Nod, the length is 30 meter and width is 6 meter. So, total 180m2 and the total cost to covert will be 180*£42 = £7560. Thanks
  5. Hi, How much will it cost to convert a commercial floor of 30 meter length by 6 meter width to 2 two bedroom flats (Build Cost only). I am trying to buy a commercial building (if planning is approved). Building has ground floor, first floor and cellar. The entire area is 30 meter length and 6 meter width. The walls are in good condition. I am looking for the cost to JUST to create 2 rooms, 1 living room, 1 dining kitchen and 1 bathroom - just the build cost only roughly. Creating the internal walls and skim them. I am NOT asking about wiring, boiler installation, kitchen installation, bathroom installation etc. I am looking for the building cost to create the walls and skim. Thanks
