merc
Everything posted by merc
  1. Thanks for advise, much appreciated - it seems getting the right roofer can be bit of a problem, maybe best by recommendation? πŸ˜—
  2. After some research I treated the suspect area with a product call Acrypol+ and it seems to be working okay, will give it a second coat when the rain stops. Will have the roof re-done in the spring, with GRP
  3. Have located the leak, but am a bit wary of replacing old felt with GRP or EPDM at present due to weather conditions, temperature etc. Is there a temporary fix - Wickes - Thompson's roof seal or similar that I could use as a short term fix. Advice much appreciated πŸ™‚
  4. Requested a quote ☺️
  5. Thanks - will check it out πŸ˜€
  6. Thanks Alan, was just wondering what the impact of being in the sun all day would have on the rubber
  7. Hi and thanks for reply, i will be getting a specialist in to do it, just trying to understand the options
  8. Hi all, new member , that needs some advise. I have a 7 year old felt flat roof with two lanterns, which has started to leak. I have researched EPDM and Fibreglass, but need professional help to opt for the bbest solution. The roof is in the sun all day long and is approximately 40 SQ. Metres Many thanks for any help
