Thanks Nick, after the liquid DPM, do I then need SBR on top, or OK to just concrete onto the liquid DPM back to level ?
Also, should I concrete in the small gap between floor and wall, or just use expanding foam ? Again thinking about cold air/damp tracking from wall to floor ?
I appreciate the help
Our mid 60’s solid floor has broken up at the edges were the carpet gripper has been fitted, and I need to repair it without causing any damp issues.
The floor consists of a thin tile on top of a black layer (15mm) of something ? On top of concrete. I was thinking of coating everything solid with SBR, then bringing back to level with a strong sharp sand mix, then painting on a liquid DPM ? Or have I got that wrong ?
There is also a 5mm gap between the floor and the wall. Can I mortar this up as well to prevent drafts, or is it an expansion gap ? So maybe use either foam or a urethane sealant ?
Thanks for your help
