Paul Stevenson
Everything posted by Paul Stevenson
  1. Hi @IAMJAMESMANNION Thanks for the question The galvanised sheet is only used on pitched roofs below 17 degrees and when you use it you do not require membrane as it replaces the membrane 17 degrees or above membrane is used. The roof is ventilated with an over fascia vent and the galvanised sheets finish over these as if you were putting on membrane. If the pitch on your roof is above 17 degrees you will not require the galvanised sheet they are used to allow very low pitches to be achieved. Hopefully this is clear if not please send me a message
  2. Hi @PeterW yes you can use Nulok as low as a 5 degree pitch by using a 0.5mm galvanised sheet to cover the rafters or trusses in place of felt or breathable membrane and then the Nulok system on top
  3. Hi Jamie Yes certainly, please do not hesitate to contact me if you require any information. Paul
  4. Hi @PeterStarck Yes I am the only supplier in the UK. I have owned the distribution rights to Ireland for approx 20 years and from September 2016 I purchased the rights for the UK from Nulok Global. I have had no dealings with Nu-Sustainable. Our distribution centre is in Birmingham. If I can be of any help please contact me.
  5. Hi Everyone, My name is Paul and I own a company called Lilyash Ltd who are the Distributors of the Nulok Roofing System throughout the UK and Ireland. The Nulok Roofing System allows any natural slate or ceramic tile to be easily fitted to the roof using unskilled labour. I have over 20 years experience within the roofing industry and have self built my own house 20 years ago. This is background information on what I do and I will not be selling on this forum, but I am here to offer any assistance or advise that you may need. Please click on either of the links below which will show how the Nulok system works. Nulok & Kingspan - The Ultimate Roofing Solution A Superior Way of Fixing Roofing Slate Looking forward to helping anyone in any way I can.
