memphisshades
Everything posted by memphisshades
  1. I'll try and take the cover off shortly and changing the fuse. Doesn't look too good with the rust does it . . .
  2. Is what I think is an LED actually an LED? Do you think its as simple as the fuse in the plug needing to be replaced?
  3. Theres 2 copper pipes that get hot. From what I see the copper pipes flow to the white box unit and 2 plastic tubes that run under the floor. The plastic tubes don't get hot though
  4. heres some photos
  5. not sure what is meant by zones but the floor is heated in a hallway and room next to the hallway separated by a stud wall
  6. There is a thermostat on the wall. It clicks but no heat. I don't know if what I am looking at is an LED or not. What is the purpose of this box? If there are 2 hot copper pipes going to this box and then rubber pipes coming out and going to the floor I don't understand why water needs to first go into the box.
  7. Hello, I have underfloor heating in a new house I have moved into. The 2 copper pipes are hot going to a small white boiler-like box (no display, a possible green led that is not lit, i say possible i do not know if it actually is an led) that has 2 plastic pipes (not heated) going into the ground. There is no heat coming up from the floor though - I guess because the plastic pipes are not hot. The small white boiler-like box is plugged into the mains. I had hoped some members of this forum may be able to help - thanks
