MrJMegson
MrJMegson's Achievements
New Member
New Member (2/5)
0
  1. Hey guys, I'm not a sparky and am intending to install my own Solar PV system. I so far bought the panels and inverters, and am trying to get batteries. I want 8 X Pylontech US5000 batteries ideally (4 on each inverter). However, I think I've F'd up. The inverters I've bought are FOX H1 6kw Hybrids. Everything about them seems perfect except for the battery connection. I looked in the box yesterday and noticed the battery connections are via MC4 6mm connectors, rated at 50A max. Now to me this doesn't sound sufficient at all, I think I need way thicker cable and a much higher Amp rating. The inverter has the following specs: Bat volt range 85-450v Recommended voltage 300vdc Max charge / discharge 6000w Max charge/discharge Amps 35A Battery spec: 48v nominal, charge/discharge 43-53v, recommended charge/discharge 80A, Max continuous 100A, peak 15min - 120A, 15sec - 200A. Are these totally incompatible? The stats on my inverter seem to suggest to me that it can't handle any large batteries. I hope you guys can explain this to me. Thanks, Jason
