Hi I'm going to do a 3.6m x 3.6m patio, I'll be using, new paving, but nothing fancy just plain 600mm x 50mm, with a mortar base of 40mm.
So what depth should my sub base be, I'm reading that the standard should be 75mm, just wondering though could I get away with 50mm, it isn't soft soil, and fairly untouched, apart from me digging out the weeds.
I had a look on paving expert UK, and it seems that the usual depth is between 75 - 100 for patios, but it is a little vague in areas, and says that sometimes no sub base is needed, so I'm thinking then why not 50mm or is that too thin.
I'm a novice I've layed a small path, with 3x2 x 50 mm, and done a couple of other jobs, but the patio will be more of a challenge, so I want to get it right and have it look nice, and as I said I'm using 600mm x 50mm, so I'm not sure because of this you can get away with a smaller depth of sub base, or its the total opposite because I'm using a heavier slab I need a thicker base, Thanks.
