spagettilegs
Everything posted by spagettilegs
  1. I have a Neura heat pump and my thermostat has failed (Theben RAM 797 b). I'm looking to replace it with another more modern one I can use with an app etc. My question is, can I replace it with any thermostat or do I require a very specific type thermostat to run the heat pump? Thanks for any pointers
  2. Many thanks for the replies. I figured a steel rsj would be the best option as it would go the 2.6m width. would a 100x100 or 200x200 be the best thickness?
  3. Many thanks for the replies.
  4. I'm building a new porch and removing an existing entrance. At the moment there are three exiting lintels over a door and two side lights. I'd like to remove the existing doors, sidelights and exiting lintels to install double french doors with sidelights which will extend from wall to wall (2.6m) It's a timber frame house with a block leaf so the blockwork above the entrance isn't supporting anything other than the blockwork itself. The entrance wall I want to remove is 2.6m and the question I have is what size RSJ should be installed to support the blockwork above which is approximately 1,500kg. Thanks in advance for any assistance.
