Robbb
Everything posted by Robbb
  1. Thanks, yeah they are non slip. Yeah a laser level is a really good shout. The fillet under the door might be a little annoying. I was originally thinking to have some rubber pads on the fillet and sit the tiles on that. Also allowing for proper drainage from the drainage holes in the frame. Although, looking at it more closely, I think I'll need to try to avoid having any strain on that fillet. Perhaps have some shallower pedestal to sit butted up against the fillet with some leveling underneath.
  2. Hi, I wanted to get some advice on a balcony that I want to fit with tiles. I was thinking to have them raised on pedestals. The tiles we've chosen are 90x60 cm. I was planning to lay these in a brick like pattern. With six pedestals per tile. The theory is that the pedestals should allow the water to flow underneath. I was going to put a thin layer of rubber padding under the pedestal to protect the roof. These could then easily be lifted if any roof repairs were required. It are there. Any thoughts on this approach or any advice I should consider?
