Novice894
Novice894's Achievements
New Member
New Member (2/5)
0
  1. Thank you everyone, that’s reassuring. I’ll take a further look when I’m viewing the house again tomorrow.
  2. Here’s the photo…sorry I had to crop it to get the right file size.
  3. Thank you all for your help. I have a photo but the size is too large, trying to work out how to do it at the moment! The plaster board joins in the ceiling are all quite obvious now, some have been painted over, some hairline, so the ceiling looks like it needs taping again possibly? But it’s the staircase crack which is worry, I’ll try and upload a photo. I can’t see anything outside, but the drive looks to have sunk as the concrete around the drain is cracked and raised. Not sure if the two are related, I’ll try and get the photo
  4. I’m considering purchasing a property but I’m unsure if the ceiling crack is anything to worry about, it’s like a staircase crack on the ceiling, starting above the window (I can’t see if the crack starts on the wall as it’s covered by wallpaper), and goes across to the corner of the chimney breast, a section of it seems to have a slighter wide crack.
