woz
Everything posted by woz
  1. I do wonder if there has been an element of this. The person in question spends the best part of every summer away from the property so the "enjoyment of property" in the original mail would have been less him. Also some of the comments in the objection to the planning permission don't sound like his thoughts. Anyway... reasonable all the way.
  2. Whilst your suggestion has a great deal of appeal to it I really honestly do not want to cost the guy more than I have to... I know he started it, I know he is being unpleasant and obstructive and he may consider me as an "enemy" but I don't have the energy to do the same to him, he isn't worth it... However I certainly am not going to spend my own money on it for now
  3. There are various dates on the deeds for various matters but the one we are looking at here is rights reserved by a conveyancing dated 1953
  4. Thank you @Adsibob and @AliG (and the others who also mentioned it) - You and other people in this topic have rightfully suggested that I check the deeds and I have taken that good advice. I don't want to get in trouble with the Land registry by posting the full document here and I certainly don't want to post anything which could be used to identify anybody so I will remove all distinguishing information and also reference to the plans. The following is from the title deeds for the property of the person who has raised the complaint (bits underlined are my edits) "Together with the right in common with the owners and occupiers for the time being of (The houses between the person complaining's property and the end of the row) and all other persons authorised to use the same to go pass and repass on foot only over and along the passage way four feet wide situate at the rear of (the houses between the person complaining property and the end of the row) aforesaid and on the South West side of (The first property in the row where the passage joins the street) Except and Reserving unto the Vendor and his successors in title and the owners and occupiers of (The rest of the houses including mine) aforesaid and all other persons authorised by him or them the right at all times to go pass and repass over and along the passage way Four feet wide at the rear of the premises hereby conveyed and (reference to the plan)." Now... I read that as I have a right to foot access along the row. But ALSO that anyone I can authorise my workers to do the same. -There is nothing in here about the right to enjoy property -There is nothing in here about not being able to move materials -It specifically allows me to pass at ALL times If I may reiterate a previous posting... I don't believe that I am a monster and I am hopefully not an idiot (although my partner may suggestion otherwise on occasion). I was never going to give the contractor permission to drive motorised vehicles down the easement (it's MAX 4 feet wide and the surface isn't great). I suppose that his only remaining complaint would be if he considers that wheel barrows, sack truck, and potentially pallet trucks don't constitute foot traffic. However I could then use the evidence that he himself has used barrows, sack trucks, and in one case a custom made dolly truck for moving concrete beams for beam and block flooring to suggest that this is a normal use.
  5. Again, thank you for your response. You have provided me with excellent information and a good recommendation for solicitor should I need to resort to one.
  6. Well if you were to take a photo of the back end of the houses you would be able to see that extensions have been built on almost every single one (there are >15 in the street) since they were first built. The most recent was the one that the person complaining built themselves
  7. Thank you, that's a good point. Yes there are both water main and sewers which run through the gardens. It would be interesting to get a response on this matter from his solicitor. I'm very sure that he would reply that if it was an emergency to fix drains / water mains then he would not object. That would show for sure that he is using this course of action specifically in protest against my development. I wonder however if that would impact on the decision made by a court.
  8. Thank you, checking the deeds is on my todo list. The houses are very old and the deeds probably aren't that specific. However we can prove that the path has been used for access and moving building materials for > hundred years.
  9. Now that is a VERY interesting question. I will have to check.. Thank you very much.
  10. There are other ways into my property without using this path. They are much less convenient (unpaved track / up steep steps) but I am sure that a good contractor would be able to work something out. There is also a neighbour who has permitted me access through his garden before. He's a nice guy but I don't want to impose on him more then I have to. Ironically I would have readily negotiated a position where the path access was ONLY to be used in situations where the other access was impractical, regardless of it being longer or less convenient for the workers... he just didn't give me the chance to talk it through before contacting his solicitor. As long as he is paying I'd be quite happy now for him to take it to court just to clarify the situation as to what is and is not acceptable use. Then I can work with the contractors to make that happen. At the moment it's the uncertainty due to the vague demands he made about "heavy machinery" and "builders with materials". Also, if he took me to court I would have to talk to the other residents who also rely on the same easement. They may have something to say about a situation where they could also be prevented from use of the easement. What about a situation where urgent remedial work needed to be carried out on buildings?
  11. Hello all, In case anybody was following / interested I have received a follow up by email from the other person's solicitors. For interest I have included it below. In my mind it doesn't really move anything along so after the good advice I have received here I am thinking of responding politely with the following points: Whilst I am happy to communicate through whatever means the other person prefers I recognise the costs that they are incurring using a solicitor and so I would invite them to communicate with me directly if they so wish. Could they clarify if their objection to the use of the easement is total or if they are concerned about excessive use? If they are concerned about excessive use then would it help to assure them that I have always intended to ensure that my contractor takes all of the residents needs into consideration and that I would be very happy to supply more details and negotiate with all of the residents at a time when the amount of materials needed has been confirmed. What I would like to say is: Any use their clients made of their own property would be without relevance but what about the use they made of the property of the other people in the street between their property and the entrance? Does that set a clear expectation (By prescription)? He did know what I had planned as he was going to help calculate the load on the walls and we had talked about plans, the only parts he didn't know were small details of the design (windows). I decided to use an architect because of a few reasons including that he would do any work in his own time and I'd prefer a business relationship (never do business with friends) Given that he was aware of the project "in general" well before I changed to an architect it would seem that his objections to right of way are a continuation of his objection to the design of the building through another route When I said that bringing materials in would be "up to the builder" that was a very short sentence. He didn't attempt to clarify that and if he had done I would have told him that what I meant was that the builder would be the one moving the materials. It didn't imply that I would give the builder the freedom to do whatever they wanted (friends / neighbours / good will of residents). It's odd for a solicitor to use the word "accept" as though they have accepted a decision. Surely the solicitor should be saying that the 3rd party is "accepting" that planning permission has been granted and "stating" that use of the passageway is a separate legal issue? If their objection to the use of the easement is "total" then they should take the matter to court without delay so that it can be clarified. The solicitors correspondence: "Any use my clients have made of their own property or the passageway is entirely without relevance. It would not set any legal precedent on which you may rely. It is my understanding that my client had agreed to help you, as his neighbours, with your extension design and drawings. However, when he realised the extent of what you had planned, he withdrew over concerns on the impact it would have on his property. You then employed your own architect from late 2021. In previous discussions with my client you were asked how the materials were to be brought on site and replied that this would be left up to the builder. Regarding the final paragraph, whilst my clients were disappointed that the planning application was approved, they accept that planning permission is only one aspect of being able to carry out works. The use of the part of the passageway which is within my clients’ title is a separate legal issue you must deal with before works can commence if you choose to use this potential access."
  12. Thank you for the detailed answer. It gives me a great deal of hope. Issue i "should" be pretty straight forward in my case, the houses are 200 years old and the pathway in question runs unbroken along the rear of the properties. A few of the occupants have added gates (never locked) to stop pets / children from straying. Reading the link you provide the only bit that worries me is the "excessive use" but any increase in use will be temporary (The project is an extension, not a new building). Thanks
  13. This is very good advice should offers of mediation fail. The letter from his solicitor talks about the ability to enjoy his property instead of any physical damage. They are retired and thus they may be at home during the day but I would certainly be telling my contractor that they should not be making noise outside of reasonable hours in a residential area.
  14. My spouse is more upset with them then I am.. but I agree with mediation.
  15. Thank you, I agree with ALL of this and when the time comes I will carefully re-read your response to make sure I don't forget anything
  16. I tried that after his objections to planning. I wonder if I made it worse at that point by highlighting that I was sad he had taken official action to complain, how he could have come to me directly, and how if the planning was rejected and had to be appealed that would cost me. I don't think that I ranted, accused, or threatened but who knows how he took it. I think that I may tell his solicitor that I would be extremely happy to have mediation on the issue and discuss face to face with an independent 3rd party (I'd even be happy to pay for the 3rd party)
  17. Thank you, that is what I thought What is concerning is that his legal letter was vague. It doesn't say what he considered to be "heavy machinery" for example. It does say that he thinks that the passage is "normally" used "four times per day" which may be right on a quiet day but we've used it dozens of times per day for days on end when people have been having work done. That's why I am sad that he has gone straight to his solicitor. As per other replies here he was a GOOD friend. That makes sense Thank you for that, I may have to talk to a solicitor after all From great friend to this in less then 4 weeks.
  18. Thank you for this. I will have a good read. n.b. After my engineer has completed the technical design and I know what we are going to build, how much materials, what timescale then I was going to knock on each door in the street between myself and number one, explain to each of them, ask them if they had any concerns (night shifts for example) and make sure that my contractor acted accordingly. Also note, I am wondering if I should share his actions with numbers 10-14 who also use the same passage and may at some point in the future also want to carry out some building work... However at this time that feels petty.
  19. That it what I did, I made sure that his solicitor was aware of some key facts and asked some question. I don't want him to keep wasting money on solicitors. If I don't get a response within 28 days (time is not an issue for me at the moment, we aren't planning on starting until next year) then I will follow up with a suggestion that I would like to have a mediated solution and an offer to do so directly and not via his solicitor. However if he wants to communicate through that solicitor then I can't stop him spending his money)
  20. Looking back, I think that the first thing that upset him was choosing an architect over his offer to design the project. The next pain point was that the architect put in for planning permission on our behalf and I didn't go and tell him explicitly or show him the plans before the architect put them in. (The planning process was all totally normal, information posted, plans shared with neighbours etc, he is not a direct neighbour but is only a few doors away). Next, when I found that he had put in a long list of objections I did go and speak to him. My position was that I was sad that he had felt that he had to raise an official objection when he could have knocked on my door anytime and highlighted his concerns. If he had done that and we had agreed I could have unilaterally pulled the application and refiled with changes. His position was that it was his "right" to complain". Even at that time we continued cordial relations with him (ironically down the disputed passage) helping to move some blocks, cement, and hardcore for some garden steps I am building. Then, when the planning was approved, he knocked on my door demanding we exchange keys (up until this point we had keys to each other's properties and would water plants, lend / borrow tools) and muttering about "unthinking about the impact on neighbours". The legal letter appeared a few weeks after that.
  21. Hello all, Looking for thoughts, comments, suggestions.. I live at number 9 in a terraced row where the access to the back gardens is via a right of way from number one along the back of the gardens. The right of way has been in place since the row was built (roughly 200 years) and during that time it has been used by owners to carry out building work on their properties (almost every single property in the row has had an extension / renovation work over the years) I recently obtained planning permission for an extension and since it has been granted one of the residents between my house and the end of street has engaged their solicitor to send me a letter stating that they are concerned about "the interference with their enjoyment of their property" and will not allow my contractor to use their section of the shared passageway to transport "heavy equipment and materials". The letter also states that if I "infringe" they will take court action to obtain an injunction to stop the works and "will result in me becoming responsible for their legal costs". (I quote the letter). I'm thinking that I will need to obtain a solicitor which is a shame, I think that I have had good relations with the other residents of the street and I was fully intending to talk to them all and ask for concerns before starting any work - The house owner in question has, within the last ten years, built their own extension and transported many tons of materials down the same passageway. - I'm not a monster - I was fully intending to tell my contractor that they would need to be most sensitive to the neighbours and move materials by barrow / hand even if that would be more time consuming or expensive. (in the same way the other person did) - I'm not sure even what "heavy machinery" they could be referring to. There is a chance that some underpinning may be required but my engineer has suggested that could be carried out in a less intrusive way. I certainly wasn't going to suggest to the contractor that they drive ANY machines down the path, it's not wide enough! - I would be very happy with agreeing not to move heavy machinery down the passage but workmen with barrows and carrying materials???? - I'm totally unsure as to how they intend to make me pay for their choice to take out an injunction? If they successfully take it out and I breach it then yes, I am sure I would be liable for damages but I can't see how I could be help financially responsible if they unilaterally chose to go to court to take one out... - I'm not a monster II - I don't WANT to get solicitors involved, I would prefer to talk and mediate but this resident has gone for the legal option... Other interesting information The resident is a retired civil engineer and up until 6 weeks ago I would have considered him one of my best friends. He has helped me move materials and build other projects on my property (barrowing many tons of materials over the years). At the beginning of my project he was offering to help with the design of the extension and we even discussed the underpinning). In the end I didn't take him up on his kind offer to design the project, I chose to go with an architect / engineer / contractor combination who knew each other and had worked together on projects in the past. He then objected strenuously but unsuccessfully to the planning application on the grounds of size and overlook into the back gardens. Thank you for reading this... Anyone had similar issues? Do I bite the bullet and spend money on a solicitor?
