I'm having a real trouble deciding on boilers to install in my rennovation project. Gas combi boilers and underfloor heating - are they a suitable match?
		My ground floor has recently had 100mm concrete slabs put down with wet underfloor heating within them. about 80m2 in total and I spaced the pipe at around 150mm.
		First floor still has rads.
		It's a stone cottage that's been extended a couple of times. It's not the most energy efficient but te extensions have cavity insulated walls and double glazing.
		I am concerned that installing a combi might lead to short cycling of the boiler if the draw from the underfloor heating is lower than the minimum output of the boiler. I have read online that it is better to have a buffer tank in between boiler and UFH manifold but all of the Gas safe heating engineers I've had around don't think this is an issue. They all say combi will be fine.
		I am particularly drawn to ATAG's boilers which have a 10:1 modulation range, meaning a 35kw could range down to 3.5kw. I think...
		Can anyone offer some guidance? Am I worrying unnecessarily or is a buffer tank necessary in my situation? Thanks in advance!
