pacemaker1000
Everything posted by pacemaker1000
Manifold controller not calling for heat?
pacemaker1000 replied to pacemaker1000's topic in Underfloor Heating
Had two red herrings.š bulb gone in 'heat demand' tested with metre and ok. temperature sensor in wrong place. Was on 2nd manifold tee meaning only way it got heat was conductive and not flow. adjusted and boiler now comes on at 40 and off at 45 -
I have two manifolds on two floors. Second floor is working perfectly, room stat calls for heat, actuators open, pump comes on and demand light comes on and calls for heat from the boiler. ground floor has suddenly stoped demanding heat? stats on, actuators open and pump comes on but demand light doesnāt come on and boiler wonāt start? thanks
Both open just a quarter turn
I do have them but turned them off as temperature already controlled by blending valve doesnāt make sense to cool down the controlled temperature with cold water š¤·š¼āāļø
So you saying 30-35 is the flow temp? any thoughts on the manifold mixers? Why would you use them if the flow temperature is already set correctly?
Cheers guys especially for the PDF diagram. This is exactly my setup! I do have two manifolds and both are in concrete so same temperatures. any ideas on settings for 'room temp' and 'limit' I thought the ideal temp was about 40 degrees so expected to see a dial to select that not room temp set to 25 degrees as that is the desired room temp controlled by individual stats in the rooms? also donāt see point in mixing valve on each manifold when both require the same temp from the boiler? if the flow is sending 40 degrees to each zone why would you want to cool that down with the return cool water?? cheers
This was in house on purchase. so does it work as I described? why would I need a gate valve or any valve on the manifold given the setup! looks like in theory setup is correct just that itās at the boiler not the manifold to save having to do it twice for second floor. valves on manifold were a mistake control panel set to room temp of 25 which is about right also max of 40 makes sense for UFH?
Ok itās starting to make sense I think š¤ back at the boiler there is a 4 way controller I assume is for temperature control see pic. It has five settings and is currently on '0' It connects to boiler flow, manifold pump, manifold return and boiler return there is also a temperature sensor zippa tied to the manifold flow. see pic of temperature control panel and please advise on setting. All my underfloor is in concrete! with this in mind my thought is the original post and pic of control valves on actual manifold , this is redundant and should be fully closed as it interferes with the 'proper' temperature control near boiler as it effectively cools the set temperature in the flow? I assume itās located there as I have two manifolds , second one upstairs, and this is able to control both? would be nice to have a physical temperature gauge to check it is does g what it should. Maybe a clip on one somewhere thanks
Hi guys, yes itās a mixer valve no a stopcock sorry. Wrote that to better describe its physical appearance as can be seen in the new pic. pump is back by boiler not near manifold and as you can see no temperature or pressure gauges. So no way to know where to set the mixer.?
Sorry no pic yet but my manifold has no temperature gauges and only a manual stopcock between flow and return. so how do I know how to adjust the stopcock so the cooler return water ensures the correct temperature in the flow? considering a clip on thermometer and turning stopcock until itās around 40 degrees? setting boiler at 40 degrees and turning stopcock off? thanks
Thanks guys. Few answers⦠house built 2005 efficiency is C 82 design from company if for 18kw ASHP to include DWH Direct replacement will mean hot water tank could be used and topped up with immersion by cheap rate or solar so not a priority. current UFH set at 35-40 I think so not high only 3 rads in house other 12 rooms UFH if on all day what would it cost once reached temperature? thanks
My current system is a standard oil boiler heating UFH and HW (300l tank). Although I currently use the immersion for HW with cheap electric and may also use solar. so boiler is currently off and will only be used in winter for heating only. Boiler flow and return only connection to boiler so can this just be swapped to an ASHP flow and return pipe work? probably a stupid suggestion but would appreciate comments
Oil to ASHP. Can I? and do my numbers workout?
pacemaker1000 replied to pacemaker1000's topic in Air Source Heat Pumps (ASHP)
Sorry Hugh I donāt understand why youād query getting the grant? ASHP cost is around 4-5k as donāt get vat back on direct purchase. Plus install would be at least Ā£2k, so Ā£7 in total? with grant itās completely free or at most just the difference in a 10 and 12k pumpā¦.no brainer? re other comments: I would run hot water on whatever is the cheapest which would probably be Pump during cheap electric? During this time in winter I would take advantage of cheap electric to heat all rooms to about 22*C, or at least best it could do as concrete will then retain heat during most of the day and Pump would kick in when needed. So question would be whether Pump could cope with DHW and heating during this short period. of course in Summer HP is not needed if using alternative ways for the DHW. This would mean he ASHP would be turned off completely for 6 months and donāt know if this would be a bad thing so using it for hot water may be necessary? -
Waiting for clarification from installer but may get away with 10kw which given current grant would be free! slight cost if need bigger pump seems a no brainer if it works as itāll cost Ā£2k in oil and probably same if need new boiler soon due to age. installer not sure if HAVE to include hot water too to get grant, which could always disable, as only need 34c for underfloor heating -
Yes hot water on cheap tariff. Enough for three showers and a bath at moment for 75p a day. This maybe changed in future to solar electric -
Spoke to installer who says rough rule of thumb is 50watts per square meter seems about right suggested a 10kw pump as sufficient and would work harder than bigger one. Be more efficiently too. RHI grant will cover cost of pump and expects installation to be around £2000 as oil boiler is old and be circa £2000+ To replace it seems a no brainer? -
Thanks for all the great replies. Good to know it is feasible to use an ASHP with my setup. should clarify all my UFH is in concrete so heat retention is excellent hence running during cheap hours. Would probably set all room stats to 22c during this time. -
Hybrid looks good as a backup but doubt the 5k grant would allow it. going back to original post. If a need 20kw a day, which would be best? Small pump flat out or biggest I can get? I have 4hrs of cheap off peak electric so would make sense to run continuously during this period so biggest would be cheaper to run only three small rads that hardly used as in attic space -
Thanks never knew about hybrids. think Iām pretty well insulated. Boiler packed in once and house stayed warm for days. I thought I could use my existing energy figures and just replace boiler KW's with electric? -
Large house with 90% underfloor heating, just 3 small rads hardly used. current oil consumption 2500 litres per year of which I estimate 700 hot water. Switched water to electric so working on 1800 litres for heating used 6 months of year in UK climate or 300 per month and 10L a day? boiler is 17 years old so assuming 80% efficiency and read 1L oil approx translates to 8kw of energy so 10x8=80kw? So I need an 10kw ASHP on for 8 hours or 16kw for 5 hourās continuously? ASHP has a ratio of 4to1 so cost would be 20kw a day excuse if this is garbage š
