Hello all,
I'm planning a self build solar array, looking to use some of the new Canadian solar 655w panels in series.
Looking at the max output current on these, it says 17.2A on the data sheet.
Looking to run these in to a 4kwh inverter. Looking at the inverter data sheets, I figured you need to look at the max input current that it's rated at, however I notice most of these are around 12A...only the Sunny Boys seem to be around 15A.
I asked a supplier what he thought and he came back and quoted me the short circuit current rating for the inverter, a Solis, which was 22A.
I'm puzzled why he would use the short circuit parameter, surely you have to go by the max input current?
Second point...if you connected these 655w panels in series to an inverter string whose max input was 12A, would the inverter merely clip the current input if it went above 12A?
Any advice would be greatly appreciated...
Thank you
