Hi, 1st post!
	We completed our self build a year ago and I have been trying to find the most economical way of running our heating and DHW system but can't seem to find a conclusive answer, so hoping someone here may be able to help.
	The set up we have is as follows:
	Basement - UFH: barely required
	Ground floor - UFH: main heating source of house. Blend valve set at 30 degrees
	1st and 2nd floors - rads: barely required
	Gas boiler- 30KW Intergas RF
	Cylinder - Kingspan Ultrasteel 300L
	MVHR system
	The boiler is currently set to fire at 75 degrees to get the cylinder to 60/65 for legionella, but this seems a huge overkill when the UFH is blended to 30 degrees and the cylinder not needing to get above 50deg (?).
	Other info, the boiler normally fires for about 4hrs a day in the morning to get the ground floor to temperature and but then needs no more until the next day. This normally raises the temperature a couple of degrees. The timer for the cylinder is set to come on once a day.
	I am thinking it could be more economical to lower the boiler temperature to 55 degrees, and maybe run an immersion programme once a week (?) to get the cylinder to 65.
	I really don't know the sweet spot at which a boiler is most economical so hoping someone can give me some honest science!
	Many thanks in advance.
