Hi I’m interested in thoughts. £14k to put in full electrics in a new build as itemised below. Seems pricey, although quite a lot going on….
Appreciate thoughts…
LOUNGE:
6no. Double socket outlets
4no. 5 Amp socket outlets
1no. RJ45 outlet
1no. Telephone outlet
1no. TV outlet
1no. 3 Gang dimmer switch
1no. Pendant light fitting
4no. LED downlights
1no. Smoke alarm
FRONT HALLWAY:
1no. Double socket outlet
3no. LED downlights
1no. 1 Gang rocker light switch
1no. 2 Gang rocker light switch
1no. Smoke alarm
HALLWAY:
2no. LED downlights
2no. 1 Gang rocker light switches
2no. 2 Gang rocker light switches
1no. Smoke alarm
RISER CUPBOARD:
1no. Fire rated distribution board with RCD and SPD protection.
1no. 25mm 3-core SWA sub-mains supply with isolator.
5no. CAT6 (RJ45) leads to router
1no. Extractor fan isolator
1no. Electrical installation certificate
1no. Earth bonding to incoming Gas & Water supply stop cocks.
BATHROOM:
4no. IP-rated LED downlights
1no. Extractor fan
1no. Mirror light supply.
KITCHEN:
4no. Double socket outlets
5no. Single socket outlets (fridge, washing machine, extractor hood, dishwasher, hob ignition).
5no. Switched fused spurs (as above).
1no. Cooker isolator
1no. Cooker outlet
2no. Under unit LED tape light
6no. LED downlights
1no. 3 Gang dimmer light switch
1no. Heat alarm
DINING AREA:
1no. Future lift supply
3no. LED downlights
1no. RJ45 outlet
1no. 3 Gang rocker light switch
EXTERNAL:
4no. Up/down lights
4no. Mini floodlights
1no. Wall mounted spotlight
1no. Dusk to dawn photocell sensor
1no. External 1 gang rocker light switch
1st FLOOR:
STAIRWELL:
4no. LED downlights
HALLWAY:
1no. Fan isolator
2no. LED downlights
1no. Smoke alarm
FRONT BEDROOM:
5no. Double socket outlets
1no. RJ45 outlet
1no. TV outlet
5no. LED downlights
3no. 5 Amp outlets
1no. 2 Gang dimmer light switch
BATHROOM:
5no. IP-rated LED downlights
1no. Extractor fan
REAR BEDROOM:
1no. TV outlet
2no. RJ45 outlets
7no. LED downlights
1no. 1 Gang dimmer switch
LOFT AREA:
1no. 1 Gang rocker switch
2no. 5' LED batten fluorescent light fittings
1no. Digital loft aerial
1no. Aerial splitter
