CraigS
CraigS's Achievements
New Member
New Member (2/5)
0
  1. Hi In was wondering if I could get some feedback / thoughts on the below before I go ahead. I am having a new kitchen-diner installed and am looking to put UFH underneath a tiled floor. I have stripped the existing flooring and the sub-floor is around 50mm below the finished flooring in the room next to it. You're probably wondering why the difference, and the reason is because we fitted retro-fit UFH to the rest of the downstairs a few years back, and installed engineered floor boards. When we installed the UFH a few years back we levelled the floor and put down overlay boards but I'm afraid to say we didn't install any insulation underneath. The advice that I got at the time was that I didn't need any as it was built into the boards, and I'm rather kicking myself that I didn't do my own research at the time. There's little I can do about that now but obviously I'd like to put some insulation down in the kitchen. My plan is to - seal the existing concrete floor with epoxy resin based primer - install either 20mm PIR board or 20mm XPS board - then 16mm XPS routed boards with a cement covering that will take the UFH pipes - 8mm porcelain floor tiles So that's 44mm + epoxy + adhesive which I hope is around 50mm Does that sound reasonable? After some reading I think XPS might be the way to go because of the higher compressive strength? If I'm going with XPS do I need the epoxy primer? I'm assuming that both the insulation and overlay boards need to be stuck down. What would the recommended type of adhesive be for the above to keep the adhesive layers thin enough so that I can remain within the 50mm available Many thanks
  2. Thanks for the responses. Pleased to report some success. I swapped out the flow meter on the problem circuit for another clean one I had hanging around. (interesting to note there were some bits floating around inside the flow meter gauge after I took it out and turned it upside down). Connected it all back with, flows (fully open) are now circuit 1 (original problem circuit): 1.3l/m circuit 2: 2.4l/m circuit 3: 1.5l/m Circuit 1 is certainly much better, and not far off circuit 3 now. I figured thought that 1.3-1.5l/m is low so took a look at my Pump (Grundfos UMP3 FLEX AS 25-75 130). I noticed that I had a green LED and two orange LEDs (out of a posssible four), and after a bit more research it seems it is only running at 50% of its max output. I managed to update the config such that it is running at its max (or so I thought), and this bumped the output of the pump up to three orange LEDs, so 75% of its max. flow rates are now as follows: circuit 1 (original problem circuit): 1.6l/m circuit 2: 3l/m circuit 3: 2.2l/m A big improvement and circuits 3 is probably in the correct range, and circuit 2 a bit high, although flow rate can easily be turned down. Circuit 1 is still a bit low. @PeterW, this is an OMNIE Setup (https://omnie.co.uk/lowboard-15/). I can certainly take the manifold off and flush all of the circuits and manifold separately if we think that will help. Thoughts from here: - i wonder how I can get the pump working at 100%? Apparently the UMP3 Flex is PWM controlled. I am quite handy with electrics too and installed a Heatmiser Neo control system myself. All works wonderfully but there is nothing I came across in the setup that talked about PWM control of the pump (nor for the boiler also). Or maybe there is something that I am just unaware of. In the absence of a PWM signal, the manual says that it runs at maximum, subject to the setting (which I believe I set to 100% in the settings mode), but clearly it is not running at 100% at the moment. - I can take the manifold off and flush everything - will altering the manifold pressure have any effect. It is running a little under 2 bar right now. If I were to increase that to 2.5 bar or 3 bar, would that help? Thank you all
  3. Hi there and thanks for quick response. Indeed, it's a 12mm pipe. I haven't taken the flow meter off as yet, will give that a shot tomorrow after disconnecting the loop. I do have a FLIR also so can try that. Will post back, thanks again.
  4. Hi I had a UFH system installed a couple of years back. There are three circuits in the living room and I've just noticed that there is no flow (or very little flow) through one of the circuits. I don't know whether it was like that when it was installed. I've tried a few things a) closed all other flow rate meters on the manifold, fully opened the problem one. I see a very small increase in flow rate, but nothing much. b) connected up the hose pipe to the manifold, opened each circuit in turn to flush any air out. I ran the problem circuit for around 15 min. With mains pressure (about 3 bar) I could get around 2l/m. With mains pressure on the other circuits for the living room I can see around 4l/m and 3l/m. c) I checked the actuator pin on the problem circuit for stickiness, nothing obvious So I'm a little stumped now. I was originally thinking I had some air in the pipe however after running the hose through it for 15 mins I am not so sure. The UFH was retrofitted on an existing concrete floor using MDF boards with channels for the pipes to run through. There is wooden flooring glued on top of that now with no chance / desire to take up given the associated cost. The pressure showing on the manifold was originally around 1.5bar. I upped that to 2 bar to see if it made any difference, seems not. Any suggestions as to what the problem might be / what I can try next? Many thanks
